Originally Posted by Originalronza
(Post 3577592)
I'm sold twins it is. Looks like either twin 525's or ilmor 625's have deals on both. Should be a nice package on the new 32 predator cat
(Post 3577596)
where do you boat?
2 is always better then 1.
If you get into motor trouble, you always have 1 to make it home. Once I blew 2 motors within seconds apart. Thank god I still had the third motor to make it back to shore. True story! :drink: 3 is a lot more work then 2, but much cooler looking. Have a great holiday to all :kiss: |
Originally Posted by TexomaPowerboater
(Post 3574633)
A 30ft boat needs twins, period. No free lunches with a single engine. The money you spend on a high hp single will catch up fast to what it will cost to run twin stock power.......
Originally Posted by Rookie17
(Post 3576541)
90% of the time, those that can afford to run twins will prefer twins.
And 90% of the time, those who can't afford to run twins will sing the virtues of a single. |
I've decided the twin bbc are the way for me to go on the 306 cat, I want to have the ability to run 130 plus when I need it and cruise at 100mph for long durations. The merc 525 or the ilmors will do that
single, if I lived on a lake and twins if I lived on the Ocean.
not trying to step on your dream boat...just a few things to think about. not sure if u have been taking to the company....but 130 with 525's is right at the world kilo record. and for a much narrower hull than a DW or skater outboard boat. not sure if u r talking closed or open boat? for easy math 100 mph at wot with 100 gallons is 1 hour. not sure what tanks u will have? range and weight distribution will b an issue if u plan on doing some poker runs and running offshore. going with Ilmore 625's is cool...great company and people to work with!!! but i would be shocked if any 30' cat had room for correct shaft geometry! more so on a narrow beam cat.
if you're open to input and buying/building a new boat of this size; peter at skater has forgotten more than most manufacturers collectively have. this is why many manufacturers have had peter build their prototypes and or race hulls. doug wright should also b on that call list too. cheers mate merry x-mas and good luck with the project!! |
I run twin 300XS motors. Run them wide open forever without worrying about blowing them up. Two outboards weigh 200 lbs less than one I/O.
http://www.offshoreonly.com/classifi...o38922-en.html http://i158.photobucket.com/albums/t...corson/011.jpg |
3 Attachment(s)
mmmm I think power to weight is very close or slightly in favor of the single I/O.
Merc 300sx's are about 505 lb each short shaft version I like Whackers for sure, but extended salt running just wipes them out over time whereas the closed loop inboards will go through exhausts, but enjoy longer lifespans. Vs My setup Transom Assembly weight about 100 XR assembly about 150 (taken from nascat thread) Ilmor 710 -about 800LB about 1050 and 700 ponies. 1.5 lb / hp Vs twin OB"s @ 1010 and 600 ponies. 1.75 lb per hp These ilmor mills run flat out for hours as well. Uncle Dave |
What a rock n pleasure boat! nice minimal cabin in a 100 mph, reliable offshore.
| All times are GMT -5. The time now is 05:25 PM. |
