Sunsation vs Advantage
I have been looking a 32 Sunsation mcob and came across a 32 Advantage mcob. I am not familar with the Advantage how do they stack up ? ..thanks
Cost goes to the Advantage easily, if you have the time, I would definitely try to get on board on both.
http://www.offshoreonly.com/forums/f...-has-done.html
Good Luck
I'd suggest to really compare the craftsmanship between the two and see which one cheaps out in just the areas you see readily. No comparision between the two if fit and finish along with rigging is of any concern. I shopped both as well at one time and the difference was very apparent.
You caould tell which had employees who took pride in their work and who had obviously been with the company a long time. You'll never beat Sunsation Customer Service either.
From my observations the fit and finish is better on the Sunny. I've driven the Sunny but not the Advantage. What is most important to you with this purchase?
I always liked the looks of the Advantage, however when I saw one up close this summer I realized they are not using a lot of today's building technology for fit and finish. Areas of the cockpit and cabin looked dated. Carpet walls, glued carpet floor. Little hardware items just seemed cheap. Round cabin hatch looks 70's to me. Not saying it is a bad boat, just reminded me of mid 90's tech is all.
They feel they don't need them, and in Lake Havasu you probably don't. The boat gets on plane very easily, but again, it's not the best rough water boat, so it is not included by Advantage unless specified as an extra. The Advantages I rode in and looked at the rigging and fit & finish were not as bad as described as other have just described, not saying others aren't, but the ones I looked at the rigging was ok, not great, not like some Kachinas I looked at. Again, rigging and fit & finish is reflected in the price, you're not going to pay through the nose for an Advantage boat. Again, best advice is always go for sea trial, and get a good surveyor.
I know the 32 advantage I am looking at is a bigger boat than the 29 Scarab I had but I used the planes alot in the 29, I also run in some salt water. Not sure I want to be without them.
