-   -   mercruiser 525 headers (https://www.offshoreonly.com/forums/general-boating-discussion/268413-mercruiser-525-headers.html)
proboat-wes 01-08-2012 09:26 AM
i should know this but i dont,will the factory cmi 525 headers bolt up to standard bbc heads??
glassdave 01-08-2012 09:32 AM
Yep
smokin' gun 01-08-2012 09:32 AM
no. but they can be modified .need to drill 4 holes on each header .the 525 s have a 3/8 ths offset bolt on each cyl . nice that merc did that so you could only use their headers
glassdave 01-08-2012 09:43 AM
Originally Posted by smokin' gun (Post 3588330)
no. but they can be modified .need to drill 4 holes on each header .the 525 s have a 3/8 ths offset bolt on each cyl . nice that merc did that so you could on use their headers
Oops . . . . Are the 500 and 525 different headers?
smokin' gun 01-08-2012 09:52 AM
yes they are .525 600 and 700 .i think once the patent ran out cmi will make them w both patterns .i think they do now
thirdchildhood 01-08-2012 10:00 AM
Bolt pattern is different on the 525 heads but they can probably be redrilled as mentioned. There is not much room for the end hole though.
proboat-wes 01-08-2012 10:02 AM
thanks for the help. when the headers show up this week ill fire the drill up and reposition the holes according to my exhaust gaskets,wes
smokin' gun 01-08-2012 10:12 AM
easy to do just copy the gasket . but the stainless flange is tough to drill
tcwcar 01-08-2012 10:23 AM
so does hold true for set of 99 etop 500 efi headers too, just bought a set of AfR heads, didn't bother to check to see if the header bolt up...
smokin' gun 01-08-2012 10:48 AM
no only . only 525s 600 700
