should I build it 42ft ... >
Old 01-22-2012, 07:15 AM
Default should I build it 42ft ...
Damn crisis
diesel2fast4u is offline
Old 01-22-2012, 07:46 AM
looks nice.
yes, build it!
what software did you use to render the image?
noli is offline
Old 01-22-2012, 08:17 AM
Originally Posted by noli
looks nice.
yes, build it!
I had my 23ft 3D scanned some years ago & then drawn in Delcam.
I use now sketchup pro
Old 01-22-2012, 11:20 AM
Neno the mind boggler
glassdave's Avatar
Sketchup is pretty cool, just started using it for some building design. Have you ever tried Rhino for 3d rendering?
08 OPA High Points Champion
glassdave is offline
Old 01-22-2012, 11:42 AM
Sketchup is pretty cool, just started using it for some building design. Have you ever tried Rhino for 3d revering?
Yeah I have Rino to, but since I got the hang of sketchup, I am only using this. In the pro version you can export 2D & 3D to Autocad files and so flange lasering etc becomes easy
Old 01-22-2012, 11:44 AM
Steve 1's Avatar
What are the plans for the bottom ?
Steve 1 is offline
Old 01-22-2012, 01:39 PM
Stepped bottem is the way to go nowdays
I would go for 3 steps... but I am open for suggestions
Old 01-22-2012, 03:12 PM
Wink Keeping the Horse in Front of the Cart?
I may be a bit off here, but I know you are re-designing and building diesel power for this project. I should think you should get the power and its overall characteristics, weights and packaging done first before you get to far into hull length and design as the power and its operational charactersistics may have a huge effect on the final hull size, design, drive types and positioning?
Just my two cent opinion and suggestion as a power developer and builder.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 01-22-2012, 03:59 PM
Best Regards,
Ray @ Raylar
No, the diesel are going in a 23 ft waterski raceboat of my design.
This I got out off the fridge.
It was designed (hull sides & deck) from the original 23 footer the have the same looks.
Customer ran out of money so we never got to the hull design.
I still love it so wanted to share
here is the small one :
Old 01-22-2012, 04:29 PM
glassdave's Avatar
Cool, I think I will upgrade to pro and see how it works.
I really like the treatment on the nose of the rendering you posted. Kind of a reverse beak so to speak. It would lend itself to give a longer running surface in the same way a beak takes it away
Looks good
