Swim platform drainage?
Old 01-30-2012, 11:43 AM
SS930's Avatar
Default Swim platform drainage?
I've seen swim platforms with and without small holes drilled in the bottom side of the tubes for drainage.
I would think the holes would either clog a little in time or at least be a starting point for corrosion to start damaging the powder coating or paint in those areas.
What is the proper way to build them, with drainage or sealed tight?
SS930 is offline
Old 01-30-2012, 11:48 AM
I believe extreme marine's are sealed tight or so I've been told by someone that bought a new one
Unlimited jd is offline
Old 01-30-2012, 02:12 PM
SS930's Avatar
Thanks Jamie, any other input?
SS930 is offline
Old 01-30-2012, 02:19 PM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Sealed tight.
Sydwayz is offline
Old 01-30-2012, 02:22 PM
tonypo8's Avatar
Mine has been sealed tight since it was new from Cigarette in 1998. Well this past winter it some how got moisture inside and cracked. So now it has been drilled and tapped with small plugs. Just my .02
tonypo8 is offline
Old 01-30-2012, 02:26 PM
Both of the ones I've had were sealed. To be honest I have not seen one with holes.
POWERPLAY J is offline
Old 01-30-2012, 03:31 PM
Johnboys has holes drilled in the bottom....
kreed is offline
Old 01-30-2012, 03:39 PM
cigboat1's Avatar
Same here-- If water manages to get in there in northern climates your going to have broken tubes
drilled mine at the bottom and check every spring and Fall..
Jim
cigboat1 is offline
Old 01-30-2012, 04:02 PM
I drilled mine on the last boat I had with a platform. It froze and broke the first winter. It was never in salt though...
redbud35 is offline
Old 01-30-2012, 09:29 PM
Smile
Scot, I'd say sealed tight, but I dont live in a cold weather climate.....
PokerRun388 is offline
