Found an easy way to wax the bottom of the boat
1 Attachment(s)
Just turn it over and let my son do it, lol:evilb:
Hahahaha! That be Mississippi style!.....but, thats a weird looking 35 Fountain bottom! :lolhit:
30 Spectre, 1000 grit wet sand, buff and wax. Also fixed a few chips.
Dats ona dem split botum, dubble noched, revrs chime Reely Fast fontains.
Originally Posted by bulletbob
(Post 3624097)
(Post 3624097)
2 Attachment(s)
The bottom was etched from someone using Hull cleaner on it. Every time it went in the water it would get stained again. It took me 2 days with help to wet sand and compound it back to a high gloss. I would never attempt to do this on a trailer or even blocks.
Hey when can ya do mine
Originally Posted by Strip Poker 388
(Post 3624158)
That is the easier way to wax the bottom. I'm thinking the flipping the boat part (after pulling the motors and draining the fluids) is the bigger trick though.
Drain the oil while your at it.
deck is solid enough to lower it on blocks? no damage?
I have had a friends teenager on a creeper waxing the bottom of my cat. Now hes' off to college. Man I miss that kid.
I always heard that waxing the bottom slows you down
Originally Posted by pstorti
(Post 3624808)
It's resting on foam blocks at the point where the supports are under the deck. |
(Post 3624808)
Just like servicing some women, much easier when you turn them over. :D
Originally Posted by pm203
(Post 3624877)
X missed ya last year at the tickfaw 200, you coming back??? |
Originally Posted by LAriverratt
(Post 3624879)
:lolhit:LMAO
(Post 3624808)
(Post 3624917)
Il. I will give up a couple of mph to have a clean boat.
Originally Posted by racer-x6
(Post 3624910)
Yes, and this year I'm not going to try and drink all the beer Friday night so I can get out of bed on Saturday, lol
has anyone proven or disproven the wax=slower theory? I'm all for a clean hull too if it doesn't slow me down.
:ernaehrung004::ernaehrung004:
(Post 3625213)
must be why I missd ya. :D You doing the run both days?? we did last year and palnning on doing the same again this year.
(Post 3625221)
Cross hatch the running surface with #120 then apply a chit load of Rain-X
those foam blocks
were did you get the foam blocks
i can't find them anywhere thanks |
Originally Posted by outonsafari
(Post 3625272)
My experience shows a hull kept in water will still discolor with wax on the bottom.
(Post 3624808)
(Post 3624917)
I , so far, have only run in fresh water, but, after leaving the boat in the water overnight it does stain the hull. I will give up a couple of mph to have a clean boat.
My father was given a tub of this wax back in the late 80's. It has been sitting on a shelf unused since then up until last year. After being applied to the hull and lower in anticipation of the few days the boat would be sitting in the slip, I was amazed to find that the boat picked up several MPH at cruise and there wasn't even the usual faint waterline stain. A quick wash/rinse and the stuff came off without much trouble at all. It is the only product of its type that I've seen, and it works as advertised. |
(Post 3625272)
| All times are GMT -5. The time now is 08:43 AM. |
