Alpha 1 Ratio
I am in the process of re-doing my Chris Craft Scorpion 210. I've replaced pretty much everything on the boat and the last 2 things left are the motor and lower end. I have a new motor that will be going in once I'm done with the engine compartment but I am just now starting to look at lower ends. I see different ratios to the alpha 1. What are the differences, do certain ratios give me a higher top end better hole shot etc? And how would I calculate the lower end that I have now?
I believe v8s have a 1.47:1 ratio v6 or straight 6 1.65:1 or so & 4 cyl 1.8 something:1. Gear changes are done in the upper half. Randy
Perfect, thank you!
I believe alot of the V8's run 1:50 as well
V8 Alphas were 1.50s, then they changed to 1.47s. My 210 Scorpion has a 1.50, soon to be replaced with a 1.47
They had a 1.32 behind a 454 for two years I believe.
Originally Posted by tbanzer
(Post 3634612)
Choose the ratio that gives you the best prop selection. That is way more important than the ratio itself. If your boat/motor/drive package ran 45 @ 5100 with a 1.47, many props would be too high. Unless you plan to go above 70-75, gear it so you can use 23-25 inch props. Everything from LaserIIs up to Maxies and Hydros ect. is more or less available in that size. |
| All times are GMT -5. The time now is 12:30 PM. |
