-   -   How Long Will Bravos Last Under Performance Use? (https://www.offshoreonly.com/forums/general-boating-discussion/272079-how-long-will-bravos-last-under-performance-use.html)
Too Stroked 03-09-2012 10:13 AM
Originally Posted by Griff (Post 3636559)
The biggest factors are HP/torque, weight and probably the biigest factor is the driver.
They will last between 5 and 1000 hrs depending.
Ah Griff, but if you're a true idiot with a heavy boat and / or lots of power, I'll bet you can get less than 5 hours out of one. Sadly, I've seen it done.
:lolhit:
A.O. Razor 03-09-2012 03:59 PM
Originally Posted by Kenny Dean (Post 3636781)
They arent that expensive so if your using it for performance keep you a spare around and you can change them out in acouple of hours easy. That way you dont miss your time in the water and you'll enjoy boating a lot more!!!!
So you think 6.5-7k is cheap for an XR replacement without transom assy? Checked prices on shafts, parts, billet shafts, gears and props lately? Blow a few and you could just have bought an ASD or Konrad, to which you prefer.
Bravos suck.
thirdchildhood 03-09-2012 04:40 PM
Originally Posted by Michael1 (Post 3636155)
I was just wondering how many hours people's Bravo One drives have lasted between:
A. Blowups
l
7 hours. XR has lasted 2 seasons so far.
Allicat38 03-09-2012 05:46 PM
Originally Posted by TexomaPowerboater (Post 3636338)
+1, also depends on weight. If its pushing a 38 top gun, not going to last as long as a 28 or 32ft boat. My drives are original, pretty sure they've never been rebuilt.
Cost seemed like it was around 3500 for rebuild and 5-6000 for new.
He also needs to be looking at the gimbal ring. If its subject to a lot of rough water use the gimbal rings can go at 150-200 hours even on a stock 502 28ft boat. Previous owner had to replace the transom assemblies at around 200 hours on my boat.
One of the drives was rebuilt on your apache. During an oil change some chips came out. so i removed that one and found the upper gears had a piece missing. Replaced upper gears and went thru the drive.
C_Spray 03-09-2012 09:25 PM
Bear in mind that Fred Kiekhafer himself was quoted a few years back as saying that the Bravo was never intended to handle more than 300 hp. Given that statement, the drive's performance in performance applications is easy to understand... ;)
Uncle Dave 03-09-2012 10:03 PM
1 Attachment(s)
Heres my experience.....
An Ilmor 710 in a 5 thousand pound boat can wreck one pretty quick in the ocean.
10-50 hours on the ocean with moderate stick bursting to high speed occasionally.
If I keep my arm out of it and boat on lakes 50% of the time 100-150 hours.
Its fragile enough to where if you sending it over 500 HP consistently you should think of sonething else.
I had an old Bravo 1's gear last 10 years with 500HP against it in a 2300LB boat.
Uncle Dave
Twin O/B Sonic 03-10-2012 03:11 AM
Yikes!
Never heard that before.
Great thread by the way. Being an O/B guy my I/O owning buddies all lie to me until I get them drunk. Once intoxicated they state exactly as posted.
500 HP's seems to be the magic # where everything else gets more important.
Hole shots and being good on the sticks in the rough seems to be key from what I hear.
