TRS, what is the Max speed & Hp U got without blowing up >
Old 03-12-2012 | 08:32 PM
Rookie's Avatar
Originally Posted by 502ss
What's almost 80? Are you pushing 700hp yet?
I ran 78.3 last year. I did not dyno with the new heads I put on last year. I think I might be a tad over 600HP now. I propped it down a bit and spun it to 6000RPM, those little 454's were screaming! I was at an overall slip of 14%. Finishing the bottom in the next weeks and hopefully the slip will go down.
700HP maybe next year, one of my blowers should be here tomorrow.
Rookie is offline
Old 03-13-2012 | 08:03 AM
B38
In my past I have built some unrulely motors from spare parts. Kinda hard when you need two of everything. Next year I will build me a few 572 or 598s and see how long my TRS can handle that. Just can only do bit by bit since I am not rich.
B38
B38 is offline
Old 03-13-2012 | 01:28 PM
Rookie's Avatar
B38
And the Pin Has Been Pulled!!!
Rookie is offline
Old 03-13-2012 | 03:02 PM
How bad was the hook? I should check mine!
502ss is offline
Old 03-13-2012 | 08:35 PM
Originally Posted by TOASTY
what did the yellow manta fever run?...I believe that and a 30 scarab indigo ran into the 100s...with trs and small block power...
I believe you hit the nail on the head. Fever ran 103 w/700-730 hp olds small blocks by Zul/cropper. Indigo had 700+ kurts marine small blocks w/ home made extension boxes and ran 101-103 also. 2 of the baddest offshore boats...period
no limits is offline
Old 03-14-2012 | 07:51 AM
B38
Now that id what i want to hear, cool tripple digits. I belive a good stick man can keep a drive together. If one blows, there are a thousand more out there to buy. Unlike #6 are fricken gold and few and far.
B38
B38 is offline
Old 03-14-2012 | 08:04 AM
Gladhe8er's Avatar
My Mechanic has a 40' Activator with triple blown small blocks(434 CID, 700 HP) and TRS drives. Has run 106, but still needs more dialing in. Never had a problem with the drives. However, he is doing a bravo conversion currently.
Gladhe8er is offline
Old 03-14-2012 | 02:11 PM
How many of these fast TRS setups are running original x dimensions? The boats I've been around mid 70s seems to be about it for a twin engine v hull with the prop shaft 7-8 below the boat. Except, If the TBs 28 cig is the one I'm thinking of (lots of nitrous though).
kvogt is offline
