-   -   drive not raising (https://www.offshoreonly.com/forums/general-boating-discussion/272699-drive-not-raising.html)
fountain44 03-18-2012 07:45 PM
drive not raising
My trim pump just goes down and clicks when i push the up button. Any ideas
kidapache 03-18-2012 07:58 PM
solenoid is bad there are two one for up and one for down
fountain44 03-18-2012 08:01 PM
thanks
mike tkach 03-18-2012 08:07 PM
put some viagra in the oil res,it will go up,if it stays up more than 4 hrs,call a merc tech.:lolhit:
Rookie 03-18-2012 08:07 PM
Also check you wires, loose connections and corrosion will do the same thing.
DirtyJerz 03-18-2012 09:32 PM
+1 I had that issue and didnt think to check the connections. Diving underwater at the dock in 56 degree temperatures and taking pieces off the outdrive to be able to manually tie it up and get it on the trailer is not fun at all!!! :lolhit:
akaboatman 03-18-2012 11:23 PM
Come on Guys. Really You can't jump a solenoid before You jump in cold water??? Love the viagra joke Mike tkach. You just have to love real boaters.
Pot of Gold 03-18-2012 11:51 PM
check your wires & for loose connections
DirtyJerz 03-19-2012 07:17 AM
Sorry Im not a "real boater" like you! Just sharing my silly experience :whistle: Hence the reason why I said to check connections also.
Audiofn 03-19-2012 08:28 AM
Next time take a quarter or screwdriver, key... and put it across the two large posts. The drive will go up and get you out of a jam.
