-   -   seawater pump , fuel pump housing (https://www.offshoreonly.com/forums/general-boating-discussion/274154-seawater-pump-fuel-pump-housing.html)
tim brown 04-10-2012 08:56 AM
how do you change the oil without taking it off the engine ?
BillR 04-10-2012 10:29 AM
I used a turkey baster to suck oil out. worked well.
1 MAIDEN AMERICA 04-10-2012 10:36 AM
I use a syringe with that clear/white plastic oil pressure gauge line on it.
tim brown 04-10-2012 10:51 AM
those are the same ideas I had . just asking incase there are better ways . thanks
TWIN-SPINS 04-10-2012 12:13 PM
http://www.offshoreonly.com/forums/g...-sea-pump.html there is a plug you have to remove ,its under the fuel pump,,suck it out and refill with gear lube about 4 oz
ACTIVESHACK 04-10-2012 04:15 PM
I took mine off and carried them to the machine shop and had them drilled and tapped for a drain plug at the bottom.
tim brown 04-10-2012 07:20 PM
I can do it myself anytime , I just don't want to remove them this year. maybe next year .
