Changing the exhaust on a 454
I'm looking at a boat with a 454 and the exhaust goes through the prop.Can I change it to go out the back?Please reply it could be a deal breaker for me...Thanks
absolutely, not sure what you would do with the Y pipe for thru prop, as long as there is room on the transom just get some tips and cut some holes
very easy job . don't sweat it
so I don't have to change the manifolds...Just get some tips,run the pipe andcut the holes and the way I go???
You need to install a Y blockoff plate on your transom assembly and disregard your Y or you can just simply put on the corsa captains choice setup and have the option of both and not go through the hassle of getting rid of the Y
basically, yes. you will have to either cap off the Y or remove it, thats what i'm not sure of
If you want to remove the Y it is easy but will probably require the engine to be pulled. It's held on by 4 bolts and comes off easy. I just took mine off and switched to thru hull. Merc makes the blank off plates and they bolt right on.
I have yanmar diesels so only one hole needed
Originally Posted by blownhammer2000
(Post 3661511)
| All times are GMT -5. The time now is 11:29 PM. |
