Safety Tips while working on your boat!
2 Attachment(s)
Hi all,
I thought of many titles for this thread. "I tried to slash my wrist today" "School of hard knocks" 'What if ?????" "Near misses I've experianced or seen" "Took a whippin' today!" I thought I'd share a near miss accident I had today. Todays lesson - I was polishing the boat with a electic buffer with a tie on wool pad. I have done this lots of times before - no problems. I tied the pad on with a bow & tucked the cord under the cloth material in the direction it spins. This has always worked in the past. Today a hole developed in that area, the bow undid, the cord came out the hole & attempted to cut my wrist off at ~ 2800 rpm. I took a whippin! But fortunately it did not break the skin and my face & eyes were not near by. Solution - tie the pad on with a knot, not a bow, then cut the ends short. Problem solved. Maybe you too can share any incidences you have been involved in, so we can all learn to be safer while working on our boats. |
glad you came out ok
ouch!:eekdrop:
I second that...i was polishing the diamond plate in my bilge with a 7" 10,000rpm grinder/polisher...i caught my forearm with it and took it down to the meat..OUCH! happens before you know it
Better solution - loose the tie on in favor of one of those new fangled Velcro jobbies :D
yep, been bit by grinder/buffers many times :eek: |
(Post 3663276)
I'm going to suggets three more safety tips - all have caused me injury over the years.
Most of you will already know these, but some might not. Just thought I'd share some real word experiances with the newbies. I have made referances to internet pages for further reading if your interested & have cut & paste for simplicity. 1) http://www.popularmechanics.com/home...-bolts#slide-1 The Adjustable Wrench Almost every adjustable wrench design includes three main components: a handle with a fixed jaw, a movable jaw and a knurled thumbscrew. To avoid damaging the tool or fasteners, ( and more impotanatly - yourself ) an adjustable wrench must only be rotated in the direction the movable jaw points to. Where I work we now need a "Work Permit" to use an adjustable wernch that is over 8" as they have resulted in that many accidents over the years. I suggest you avoid the use of adjustable wrenches where possible. 2) http://www.ccohs.ca/oshanswers/safet...s/general.html •Pull on a wrench or pliers. Never push unless you hold the tool with your palm open. The palm open rule is compulsory where I work. Why open palm - especially in tight quarters like around an engine bay? I will guarantee you when that when the wrench slips and if you have a closed fist around the wrench, one day you will bleed as a result of striking something with your closed fist. Using an open palm to push down on the wrench will reduce this risk as the strike point / pinch point is eliminated, or at least minimized. 3) When using box cutters / knives. http://voices.yahoo.com/how-box-cutt...y-8116938.html Angle It Away From Your Body - There is no reason to cut directly towards you. If you cut at an angle, your hand will move away from your body if it slips. Very good advice. I was always told - when using a cutter / knife always cut towards your friend! Lol ! Works for me. |
(Post 3663276)
yep, been bit by grinder/buffers many times :eek: Search for 3m Hook It pads |
1) Always have a friend with a can of WD-40 within yelling distance for the day you get your arm wedged between two sets of Stellings. It can be a long and lonely wait.
2) Never wear socks on deck. Saves falling 8 feet to the driveway after bouncing your head off the bow rail. 3) Wait until the headers cool down before trying to change the fouled spark plug. Saves the skin on your hand being transferred to the exhaust system. 4) Put the plug in before you put the props on. Saves stitches in the head. I could go on but............................. :) |
Experiance speaking ................
I was actually thinking about the sock one this week while polishing the top deck of the boat! Good advice. |
| All times are GMT -5. The time now is 08:04 AM. |
