Originally Posted by mike tkach
(Post 3670147)
my buddys think im crazy,but every time i put my boat in the water,i always open the hatch,turn on the blower and smell for gas fumes,then i start them and check for leaks,only takes a minute,and if nothing else,it gives me peace of mind.electrical fires can be almost as bad as a gas leak,but probibally less common.
Originally Posted by fountain4play
(Post 3670138)
It doesn't take that large of fuel leak in an enclosed bilge to bring it to an explosive level. That's why the first thing that should be done before starting is open the hatches and do the smell test. If you can smell raw fuel you have a potential problem... Gasoline vapors even in small amounts can have the explosive potential of a stick of dynamite...after it blows usually the fuel lines are severed causing more fuel to feed the fire... This is a very unfortunate thing but it was and is preventable...
If you have a bilge full of fuel though, the air / fuel mixture is way to rich to ignite. Sometimes opening the hatch can add enough air to get you into the correct range to blow. Properly installed bilge blowers suck from the lowest point in the bilge and replace it with fresh air. One theory states that you're actually more efficient in moving air with the hatches closed. Of course with enough fuel in the bilge, all bets are off. That may have been the case here, but we're arm chair quarterbacking. Here's my point on that being a fuel fed fire though. Notice the massive flames and black smoke? Black smoke means a fuel rich mixture. There's lots of fuel feeding that one. (And yes, fiberglass & resin are decent fuels.) |
Originally Posted by Too Stroked
(Post 3670157)
Absolutley agree that with the correct fuel / air mixture, a powerful explosion is indeed possible. Also agree that the smell test - particularly in the lowest point in the bilge where fuel vapors collect - is a great tool.
If you have a bilge full of fuel though, the air / fuel mixture is way to rich to ignite. Sometimes opening the hatch can add enough air to get you into the correct range to blow. Properly installed bilge blowers suck from the lowest point in the bilge and replace it with fresh air. One theory states that you're actually more efficient in moving air with the hatches closed. Of course with enough fuel in the bilge, all bets are off. That may have been the case here, but we're arm chair quarterbacking. Here's my point on that being a fuel fed fire though. Notice the massive flames and black smoke? Black smoke means a fuel rich mixture. There's lots of fuel feeding that one. (And yes, fiberglass & resin are decent fuels.) Below the explosive or flammable range the mixture is too lean to burn and above the upper explosive or flammable limit the mixture is too rich to burn. The limits are commonly called the "Lower Explosive or Flammable Limit" (LEL/LFL) and the "Upper Explosive or Flammable Limit" (UEL/UFL) For gasoline the explosive limits are fairly low with the range being 1.4% (LEL/LFL) to 7.4% (UEL/UFL). Bilge blowers are much more effective when the hatches are closed but checking for obvious leaks before firing up only takes a second and can save not only your boat but possibly your life. On a somewhat unrelated incident where it was a natural gas explosion in a home the question was asked to one of the fire investigators what the possible ignition source was. His reply was just about anything that creates an arc or spark from a faulty light switch to the pilot light on the water heater... |
Military Fuel/Air explosives are sometimes called the poormans Nuke.
Originally Posted by Steve 1
(Post 3670189)
the propane bom...heard about that...
That is absolutely awful but at least they were not hurt. Does this happen with outboard boats as well? For some reason I always thought for an explosion you need to have some kind of igniter, spark? Are you guys saying air/gas fumes can lead to a fire just by themselves? Or does that usually happen right when you start the engine and you have gas fumes in the engine compartment? I'm really not too familiar that's why I'm asking.
On an outboard the batteries are in the bilge as is the fuel tank, get a loose connection to the battery and the same thing can happen.
What a bad break. I hope his insurance doesnt give him a hard time, losing that boat is bad enough.
Originally Posted by SpeedDoc
(Post 3670299)
| All times are GMT -5. The time now is 11:24 AM. |
