-   -   anybody have #5`s on a stepped hull (https://www.offshoreonly.com/forums/general-boating-discussion/275980-anybody-have-5%60s-stepped-hull.html)
hangem out 2dry 05-07-2012 03:08 PM
Does anyone have #5`s on stepped hull? having trouble getting on plane? what props/ x dim ect ? what works?
kreed 05-07-2012 03:18 PM
I would call Phil at Lipship Performance, he can help.
kvogt 05-07-2012 08:46 PM
boxes? How high are they mounted? How much of burnout are you currently doing?
FIXX 05-07-2012 09:12 PM
fixx
prop diameter? bigger would be better for a hole shot.
stirling 05-08-2012 12:24 AM
If you have a lot slippage or burnout during getting on plane ,there are some with #5,s that use a 1/2 inch ali plate with a offset bent ,and milled like a spacer that mount between the upper and lower .
This way the prop sits under a anti ventilation plate ,like a #3
I don,t have any pics ,and don,t know who the manufacturer is ... Ive seen it on skiraceboats that use a #5 several years ago
obnoxus 05-08-2012 08:04 AM
Buddy has them on a Black Thunder,,,,but has spacers to get them lower
hangem out 2dry 05-08-2012 02:40 PM
I think my problem is i am too high I am 1.50 above the water line to center of prop turming 17.5 4 blade 32 pitch only got on plane a couple of times ,i already have cavitation plates like #6 custom made
as a spacer.also i am on stellings boxes
FIXX 05-08-2012 05:14 PM
fixx
i would try and borrow a set of bigger props,,even if its a 1/2'' biggeer in diameter it should help.
kvogt 05-08-2012 08:40 PM
I know a few guys with either 4s or 5s on straight and stepped vees. For getting on plane there really isn't a difference between the bottom types. All of these boats are on boxes and the highest one has the drives a little over 1/2 inch obove the bottom of the boat. All of the boats run between 17.5 and 18 inch diameter and 5 blades. The props have all been labbed to add cup for bow lift and aid in getting on plane. To get any of these boats on plane fairly quickly requires a 4000-4500rpm burnout. The boat (43 Nortech) with the 18 diameter and the props even with bottom can coax his out around 3500 rpm but it takes a bit to get up.
