OSO will not fix the Photo Section,Help Please
1 Attachment(s)
I have contacted OSO tech and Internet Brands before about the photo section not working and havent recived any response. I have also emailed Robert Brisco about the prob with Internetbrands no responce also.
http://www.offshoreonly.com/gallery/ The photo section is powered by http://www.photopost.com/ .I contacted there tech dept there and they said the imagemagick on the server is broke or the data directory at every level is not 777 permissions as error code 1 is permissions. You need to set permissions on the data directory to 777 every folder beneath it and you can try uploading with your processor set to GD2. http://www.photopost.com/ Please tell me who I need to contact/prod to resolve this problem. Thanks Rob |
I haven't been to that for years. Looks like spammers trashed it!
If it is a permission thing that can be fixed in seconds, a chmod (permission change) only takes seconds, any half way competent server administrator should have no problem setting permissions.
Since GD or ImageMagick can be used it is a simple matter of them selecting which graphics engine to use. At worst a re-install of gd or imagemagick, once again something that takes less than a minute to do. They should have no problem resolving the issue. |
Originally Posted by SinOjos
(Post 3687706)
Since GD or ImageMagick can be used it is a simple matter of them selecting which graphics engine to use. At worst a re-install of gd or imagemagick, once again something that takes less than a minute to do. They should have no problem resolving the issue. Rob |
Seems to be working for me now...
Originally Posted by RT930turbo
(Post 3688146)
I just tried no go still getting code.Maybe it me? Error creating thumbnail! Error code: 1 Command: "/usr/bin/mogrify" +profile "*" -size 0x150 -quality 80 -geometry 0x150 '/var/www/html/gallery/data/3052/thumbs/Dock_Rocker_8.JPG' |
I tried to delete spammers from there a while back but was unable to do so. I reported the post at that time and didn't hear back either.
Its not just you Rob... even tho you are King :D |
Originally Posted by Racegirl3
(Post 3688348)
Im still getting spam post on old pictures Ive posted there,cant be that hard to fix with there help
Since the forum is vbulletin, it can run zzblock. I just tested the offshoreonly forum and zzblock is not running. zzblock blocks known malicious bots that post data and or look for vulnerabilities and blocks known malicious ip's. By blocking the malicious activity, it decreases bandwidth use and server resources, which lowers costs of running the forum and improves accessibility and speed for the allowed users.
http://www.spambotsecurity.com/zbblock.php Malicious posters can be blocked by ip or range of ip, if vbulletin (not familiar with vbulletin) has that capability within the admin section, that is easily done by adding the malicious ip's to the block list. If vbulletin does not have blocking capability, ip's can be blocked via httpd.conf (apache) file or .htaccess file. Either way, malicious unwanted posting can be stopped. Since zbblock is not being used, and this problem continues to persist. Perhaps some consultation is in order to implement additional security features with your existing server administrator, or move to a different service provider that knows what they are doing. My personal experience with visiting offhshoreonly has not been the greatest. It was a lot slower in the past, better speed wise now, but there is still room for improvement. Considering that zbblock is not being used and malicious posting persists, the server administrator is the first place to go, as that is were the real problem lies. |
| All times are GMT -5. The time now is 05:56 PM. |
