-   -   502 mpi wont start (https://www.offshoreonly.com/forums/general-boating-discussion/277128-502-mpi-wont-start.html)
ICDEDPPL 05-24-2012 09:12 PM
Try turning the key.. someone else can chime in here but I think the rotation is clockwise.
:lolhit:
sun28int1995 05-24-2012 09:22 PM
I fought a very similar problem last year on an HP500, turned out to be a bad rev limiter module. Engine would crank and kind of act like it was going to start, but not because the rev limiter would kick in a cut the ignition for a second. Even the spark test was showing good. Kind of like having a 2 rpm rev limit! Having someone with the proper diagnostic tools was the only way we found this without some expensive parts replacement......although that module was pricey enough!
akaboatman 05-24-2012 10:51 PM
5 post. What eng? Carb??? Do you pump the throttles??? lots of guessing ???
