is there dipstick bolts to pass car style drain bolt? >
Old 06-03-2012, 04:05 PM
Default fixx
Originally Posted by dereknkathy
there's a thought. drill bit the size of hole? or smaller? running with a drill? or turning by hand? thanks. derek.
i would do it on the smaller scale by hand and then once you have a hole going through it try to get the rest out with a pic..or just hog it out with a sharp new 3/8 bit..
FIXX is offline
Old 06-03-2012, 06:25 PM
you could use a pick and have someone hold a shop vac hose right beside.
pullmytrigger is offline
Old 06-03-2012, 07:16 PM
i am thinking maybe a lag bolt. more of an augur-feedscrew shape...
dereknkathy is offline
Old 06-03-2012, 08:20 PM
Neno the mind boggler
glassdave's Avatar
Fixall is right on, just run a drill through it but i would do it at a fairly good speed to quickly pull the stuff out of there. Do it with no oil in the pan then run a gallon through it with the drain plug open. What little, if any, is left after that will will be picked up by the screen and/or filter. Silicon floating around in an engine is far from uncommon. You should see our Olberg screens after a freshen up on the race motors. Plenty of loose debris and silicone but thats what the filers is there for.
08 OPA High Points Champion
glassdave is offline
