Can heat cause cracks in gel?
I layed the boat up on the trailer a little over 2 years ago with the engine removed. I keep it here at my house and have a good cover on it. Today I pulled the cover to replace it and give the boat a good cleaning to get it ready for sale and noticed the first gel cracks on it that I am 100 percent sure were not here when I layed it up.
Is it possible for the Texas heat to crack gel? |
I know, never assume anything!!!!
Assuming you are talking more about surface crazing rather than cracks, heat and age are the two most common causes. I have seen newer boats do it; likely from the mix being even slightly too hot when applied.
Stress (twist, flex, bowing) will also cause crazing. There are a few products which protect and hide this crazing, but it is still there, just not as noticeable. I likely need to clarify something here, it is not really heat as much as extreme. Cold will accelerate the aging process too. Fibreglas has a life expectancy like everything else and the lay-up lasts much longer than the surface. Some of the restorers I know are using more and more paints than gel when resurfacing. There are applications where they prefer gel, but as a very general statement they are going to the two part paints for ease of preparation, application, clean-up, mixing and endurance. Fibreglas is constantly improving, but the paint seems to be as, or more, durable, easier to match in a repair and more fade resistant. Sometimes true cracking can be extreme crazing! I friend rebuilt a transom. The curves and "joints" on the transom significantly cracking. Long story short, they were a result of the wood core being all but rotted out. |
Originally Posted by BoatShow239
(Post 3706603)
| All times are GMT -5. The time now is 04:13 AM. |
