496ho Problem
I am having issues with my 2004 496ho. It started idling rough, almost like I had bad fuel. Once you accelerated, it cleaned up and was fine. Changed the fuel/water separator and drained fuel and added new. No change, in fact it was worse. Still idled rough, but now it wouldn't even plane. Acted as if it was loading up on fuel. Pulled the codes and got cam position sensor, crank position sensor and MAP sensor. Mechanic replaced MAP sensor, cleared codes and boat ran fine...once. Next time out, same issues. I don't know what codes the ECM is showing, and I am not getting any beeps. I'm pretty sure it's not the MAP sensor. Any ideas what the issue may be?
When mine did this all that was required
was to change the plugs. Voila!
Originally Posted by xx14
(Post 3723337)
Could be the idle air control valve.
Originally Posted by XX14
(Post 3723337)
Crank sensor gets my vote. Just replaced both of mine.
Originally Posted by GO4BROKE
(Post 3723593)
Don't change the crank sensor yet. Those were not much of an issue in 2004 unless your engine is a 2001-2003 actual engine model year (check tag date on heat exchanger) If your plugs are original and unchanged give that a try first, also check and clean the IAC filter piece inside the throttle body if its still there. If that little filter has broken up and been sucked into the IAC itself it can cuase a condition like this. Unbolt the IAC on the back of the intake manifrold and clean it with carb cleaner and look at the plug on it and make sure its not starting to melt and distort.
Best Regards, Ray @ Raylar |
Mine are 2002. The sensor that was acting up was a little tight to pry out, the other one slid right out. Be carefull not to bend them sideways, they are not hard to break, but they ARE hard to get out once broken. Be sure to use penetrating oil, and the new ones shouldn't have the lower o ring, just the upper. Follow Rays advice first, he knows best. Good luck, keep us posted.
Ray,
Would it have thrown the ckp code if the iac was the issue? These ecm's do seem to like to store a lot of codes. |
After I bought my boat (also 496 HO) I took it to a mechanic for routine service he found one of the plugs was... unplugged.
After plugging it back in the boat ran like 8 MPH faster. So yeah, sounds stupid (I didn't even know it would work at all running on 7 cylinders!) but worth checking. |
Many times on a Merc 496 engine if there is a stall or with ECM engine stopage the ECM will record a crank sensor and cam sensor fault code in the ECM even though there is really nothing wrong with those sensors or parts. If these codes appear its always a good idea to re-energize the power to the ECM and if needed restart the engine, clear these codes and make sure these codes do not reappear after being cleared the first time with the scan tool to verify that there really is an issue with these two systems. All the early model crank sensors on these engines that had problems were the crank sensors with two O-rings and not the newer single O-ring crank sensor.
Try to remember that good trouble shooting skills and success in fixing engines comes from carefully identifying the real problem or issue and then replacing that part if needed or fixing the issue. Just guessing and throwing $$ and parts at a problem is usually very frustrating, expensive and unsuccessful. "When in doubt, Check it out!" and don't use a WAGMAR (W-ild A-ss G-uess M-ade A-t R-andom) ! Best Regards, Ray @ Raylar |
| All times are GMT -5. The time now is 07:55 PM. |
