-   -   adding passenger gauges (https://www.offshoreonly.com/forums/general-boating-discussion/280542-adding-passenger-gauges.html)
onesickpantera 07-12-2012 01:28 PM
I want to add an oil pressure and water temp gauge on the passenger side. Does anyone know if they need their own sender or if I can piggyback off the existing sender? My gut is telling me I can't piggyback because having two gauges hooked to one sender will screw up the ohms from the sender and cause the gauges to read low.
If I can't piggyback I will probably go mechanical.
senzaspectre 07-12-2012 02:00 PM
Depends on the sender you have now, if not all you need is a dual sender. (like you would have on a fly-bridge boat with two helm stations.)
