-   -   Bell Housing Shift Shaft Seal Question (https://www.offshoreonly.com/forums/general-boating-discussion/281471-bell-housing-shift-shaft-seal-question.html)
jbizub5192 07-25-2012 10:24 PM
I am replacing my shift shaft seal and I took them out over a week ago and the part just came today and of course I dont remember which way the seals go. I have looked in the manual but the diagrams arent so clear and I want to double check with what you all have to say. The 2 seals that I have in the blue box, does the spring end face into the uj bellows? if so do both of seals face the same direction? I know when I did the upper half of the stern drive they were opposite directions. Also the bushing I have in the yellow box it sits flush on the the yellow circle i have correct? or does it sit flush at the top of the exhaust port. Thanks for all of the help!!
https://lh5.googleusercontent.com/-H...%2520shaft.jpg
jbizub5192 07-26-2012 09:00 AM
Does anyone have any info on this? Thanks!
Panther 07-26-2012 12:00 PM
both down. put grease in the middle
some of the kits come with a brass piece that presses in from the bottom with both seals already installed.
jbizub5192 07-26-2012 09:40 PM
When you say both seals down you mean the spring end faces the exhaust port or does it face the uj bellows?
jbizub5192 07-27-2012 09:11 AM
If someone could answer that question I would appreciate it because I need to get this done today. Thanks!
Panther 07-27-2012 10:59 AM
down as in towards the exhaust cavity. Those seals are meant to seal water from entering the shift cable cavity, nothing else, that's why the both of them face the same direction.
jbizub5192 07-27-2012 04:41 PM
Another words I should be able to see the spring from the exhaust cavity correct? Sorry for so reason these dam seals have got me confused. Thanks for all the help!
Panther 07-27-2012 09:00 PM
Correct
jbizub5192 07-28-2012 10:25 PM
Thanks!
