Keep your Stainless steel clean!
How do you keep your props and exhaust clean without having to Lime-A-Way every trip.
Google search and found a product called TUFFSEEL. Anybody used it? Or any other stuff out there to keep the build up off? |
I spray mine with vinegar every time out and let it soak. Then wipe it off. Might take a couple of times, but better than using something as strong as Lime A Way. Keep it waxed.
S100/P21S metal soap every few trips. Soak sponge, make lather, wash, rinse/wipe off. 30 seconds goes a long way.
sounds like good stuff. do you add anything after to inhibit the buildup?
Originally Posted by Revd Up
(Post 3744886)
Keep it waxed.
Try "Never Dull". It's in an aluminum can. Works great. Also, for wiping down without a solvent, try a good old fashion foam nerf ball. Wont believe it until you try it.
Originally Posted by bsc
(Post 3745239)
Vinegar/water and magic eraser.
SnoBol toilet bowl cleaner. Wipe it on and rinse off.
Noxon 7. GREAT PROODUCT
| All times are GMT -5. The time now is 12:52 PM. |
