-   -   Setup For Weiand 177 On 454 (https://www.offshoreonly.com/forums/general-boating-discussion/282307-setup-weiand-177-454-a.html)
Boxer 08-16-2012 06:01 PM
Dialing in a blower motor
Originally Posted by HTRDLNCN (Post 3749620)
Whats your A/F looking like?
Figure out a way to determine your A/F ratio. Should be 14:1 at idle, 13:1 midrange and 11.8to 12.0 wide open. The only way to determine this is with a meter. Everything else is guesswork. Good Luck.
blue thunder 08-16-2012 08:43 PM
Exactly correct as long as you are not too close to the edge of detonation with the engine build/boost.
blue thunder 08-17-2012 08:23 AM
Originally Posted by CenturyUltra (Post 3755568)
I pulled the supercharger off to change the pulley and change the oil and noticed fuel in the oil. I just put new bearings and seals in it but never marked the rotor postion (to one another) on the gears. Do I just put them directly horizontal and vertical to each other? The gears can only go on the rotors one way and I see marks on the gears but if you line them up the rotors would hit. Thanks
You have to line up the marks. The gears are mitered so the rotor will hit until you get the gears seated to one another. Fine tuning of rotor timing is done with shims under the miter gears. Make sure those go back just like they came out or you will need to retime the blower.
