-   -   In the process of a carb rebuild, but now stuck (https://www.offshoreonly.com/forums/general-boating-discussion/282695-process-carb-rebuild-but-now-stuck.html)
jbizub5192 08-13-2012 09:50 AM
Hi everyone, I have a 94 4.3lx with a 4 barrel carb and Im in the process rebuilding the carb but now im stuck. I removed all of the 8 screws on top of the carb and I can not separate the top and bottom half! I then took a small putty knife and gently pushed it in all the sides to try and free the gasket as much as I could. When I try to lift up with the knife it feels like something is still holding it back. Did I miss a screw or something? I looked it over but cant see anything else holding it. Thanks!
Nice Pair 08-13-2012 01:27 PM
carb rebuild
Do you Know the make and model of the carb? Can you post a picture of it?
BeakBoater35 08-13-2012 03:34 PM
Is there a long stud in the carb for the spark arrestor? If so, try removing it.
jbizub5192 08-13-2012 04:21 PM
Thats it!! That one stupid stud was holding it. It would have been nice if the merc manual said to remove that lol. Thanks again
BeakBoater35 08-13-2012 04:30 PM
Your welcome.I'm pretty good at taking stuff apart. Putting it back together? Well...
jbizub5192 08-13-2012 04:48 PM
I am like that also because most of the time I cant finish it all at once and then when I find time to complete it I forgot how to put it back together lol. Have you ever done metering rods for this weber carb? Just wondering if I got the metering kit from mercruiser if it was just something I plopped in or do I have to do adjustments? Thanks again!
BeakBoater35 08-13-2012 05:32 PM
I'm not familiar with your particular carb/application.
Generally speaking unless there is a compelling reason to change the metering rods it is likely they are fine for re-use when doing a basic rebuild.
There are folks on this site who know a lot more than I on this subject. Some of them are in the business of marine repair and could do the rebuild for you.
Whatever you do, when you re-install the carb on the motor CLOSELY check for fuel leaks. Then do it again. And again!
FIXX 08-13-2012 07:38 PM
fixx
leave them alone..the only tip i can give you is to remove the little screens on the needle and seats and pitch them..they clog easy and will give you trouble down the water...
jbizub5192 08-13-2012 10:06 PM
Thanks for the tips! I think for now I will leave them alone and if I still have trouble with the carb then ill have to do it. I know the one rod is worn diameter wise but the actually length is fine.
BeakBoater35 08-14-2012 10:19 AM
The diameter of metering rods where they travel through the metering jets is seriously important. Being of the correct length is virtually of no importance.
I mean no fowl, but perhaps this job should be turned over to someone who has experience rebuilding carbs. I admire your desire to pull your own wrenches, but I'm not sure this project is a good one for you at this time. If it is not rebuilt correctly, it will drive even the best of us crazy trying to get the boat to run correctly. And, finding a mechanic who will accept responcibility for correcting an a previously unsuccessful rebuild may be a challenge.
