-   -   Portable AC (https://www.offshoreonly.com/forums/general-boating-discussion/282788-portable-ac.html)
Carguy08 08-14-2012 11:03 AM
Portable AC
http://www.westmarine.com/webapp/wcs...74&cid=E120814
Anyone used one of these? Thank you
lastcall02 08-14-2012 11:19 AM
yes, works great! I would recommend that you get one with at least 6000 + BTU's though if you plan to use it during the day. 5000 BTU's is fine if you only use it at night.
t500hps 08-14-2012 11:28 AM
Used one on a cruiser for a few years, then much later used another one on a Formula. It was a PITA to get up on the bow. Ended up using a $100 window unit sitting in the doorway with a towel under it. Worked just as well ifyou don't mind stepping over it.
RT930turbo 08-14-2012 11:42 AM
I throw a window unit on a rubber mat on the bow and let it blow down a deck hatch. Just throw a towel over it to seal it all up and it stays very cold in the cabin. Much smaller and easier to store in the closet. This was a temporary solution until I got marine AC installed, but it works so well I decided to not even install the fixed unit.
ziemer 08-14-2012 12:00 PM
Here ya go...
Can buy this little 6000 BTU window unit on Craigslist for $50 or brand new on Ebay for $150 shipped. With a $15.00 piece of foam board, some white duct tape, and a bungee, you're good to go.
http://i215.photobucket.com/albums/c...r99/AcBaby.jpg
bcfountain 08-14-2012 12:22 PM
i have a cruiseair unit that i use on my 27fever.it works great.as said,its a pita to get onto the deck.the good thing is that it is air to air exchange.so i get a better temp change.grant you the fever is a small cabin.but the output of my unit is only 4500btu output.on a 100degree day i can get my cabin in the 60,s.at nite i almost have to turn the unit off.too cold.
