-   -   Sanding a lower unit for speed (https://www.offshoreonly.com/forums/general-boating-discussion/285858-sanding-lower-unit-speed.html)
JRider 10-07-2012 10:06 AM
Originally Posted by offshoredrillin (Post 3789699)
I keep mine sanded, i started with 60 then 80 then 120 and finally 220. I keep them shiney with a 3M scotchbrite red pad and wd40. being as i have really done nothing other than make them satin finish, other than looking good i couldnt tell ya. :)
Might want to try veggie oil vs WD40...a little more enviro friendly.
4bus 10-07-2012 10:23 AM
Originally Posted by scarab63 (Post 3791622)
5 mph net is pretty DARRn good for some elbow grease.....
What's the secret hex film called...?
http://www.proboat.com/blueprint-for-speed.html
Interesting, most of us just keep adding HP
Curious to see if any DIY'ers on this site have trued a lower unit themselves.
redbud35 10-07-2012 11:56 AM
Originally Posted by nova26 (Post 3791554)
What kind of boat?
I'll bet it's a Skater...
AJ POWERPLAY 10-07-2012 12:20 PM
very interesting read... if it wasnt 5k i'd consider it
yarrowtavern 10-07-2012 12:50 PM
Its proprietary and called hex hyde. Its in testing phase on 2u boats right now. Results will be available soon
scarab63 10-07-2012 08:02 PM
no worries
Originally Posted by bwd (Post 3791626)
Better put motor in before you bother sanding your lower. Just sayin. LOL
Heads getting flowed now.
It'll b back together soon.
Don't u worry bout me Mr...u know I like to stack my plate high.
Lauderdaleboats 10-08-2012 08:50 PM
Having a true straight lower on a twin engine appllication is beneficial but i don't think this is the case on a single engine app.
Outboard drag racers have been sanding/profiling lower units for many, many years, and straight was not what they were after. Running a high x dim will result in increased speed but on a single it will try to prop walk. Prop walk will cause the driver to crab the lower to keep the boat in a straight line. Look at the skeg mounted torque tabs on the fastest of outboard drag boats and you wouldn't believe the curve. Drag boat skegs running right hand rotation props will have the stbd leading edge ground on back to mid skeg. On the port side, from mid skeg back to the trailing edge is ground on. This curved skeg is the fastest setup on a single engine.
glassdave 10-08-2012 09:05 PM
never really thought about it but that makes a lot of sense. Interesting . . . . .
CLA 10-08-2012 09:40 PM
I talked with Steve that owns RPM and he said the same. I believe he is putting tq tabs on his lowers on those little cats.
bwd 10-09-2012 05:09 AM
Very interesting.
