prop for liberator??
I have a 1987 21liberator and with the prop I have it will go 72mph. Is this right it has a 225 merc and I would think that would be a bit slow, I had it trimmed about right I messed around with the trim and the fastest I got was 72 and had about 6 inches of running surface at that speed.
Thanks Brett |
your dream meter is lieing to you by about 15 mph..
Uh, yeah, what engine do you have. You would need 500 horsepower or more to hit 70, and your alpha drive would already be dead. Fill us in.
What prop? What engine? What drive? 350/260 is usually 50-52 454/330 is usually 55-57 EDIT: I bet you are talking about the Liberator Cat...and we can all shut-up now, didn't notice the Merc 225. |
http://www.offshoreonly.com/classifi...o47690-en.html
This is my boat and liberator never put inboards in these?? Brett |
I'm pretty sure they all thought you were talking about a 21 V Bottom.
Originally Posted by Griff
(Post 3797250)
Just a note - that is a 20' Liberator.
It should run low 80s with that 2.4. They do not like thru the hub props. Find a 28" Merc ET or Mazco RE3. LT |
| All times are GMT -5. The time now is 01:13 AM. |
