Need input on 496 stroker buildup.......
#31
I am still working on my project.....got stalled a bit as I was in Miami almost all of July getting some training. I am an out of work Airline Pilot and between getting another type rating and job fairs and moving, I have been busy to say the least. I should have the engine at the dyno by the end of the week....... TBF
#34
My 2 cents I have run pro comp heads and made good power my only issue was stripping the exhaust bolt hole threads and for the same money get a set of pro header heads bare have all the good stuff put in and run it hard better castings
#35
Next engine will get AFR heads and headers for sure!! Motor is getting Installed this week. Got my reversion issues fixed with the 496 manifolds. The pro-comp heads needed quite a bit of work to correct some issues but it sounds beefy!
#36
SORE MEMBER
1 Post
Somewhere in this thread it was recommended that you email or call Bob Madara with Marine Kinetics with your proposed setup, 585-654-8583
IMHO he is a priceless resource that is available here on OSO
Good luck with your project
#37
I have seen a few guys try pro-comp heads because the price is just too tempting. Every one of them had some sort of issue with them. Stripped bolt holes is a common problem but I have also seen bolt holes out of location, valve guides not properly installed and even one combustion chamber 1/4 inch out of location. Seems like they have serious quality control issues if they even have such a thing.
#40
