-   -   Lower Unit Drive Lube washer (https://www.offshoreonly.com/forums/general-boating-discussion/289040-lower-unit-drive-lube-washer.html)
seafordguy 12-18-2012 10:44 AM
Anyone use anything besides that crappy blue fiber washer?
If I used an o-ring or something would that work better or does the pressure in the case cause it to leak?
Sydwayz 12-18-2012 10:47 AM
One of the great outdrive debates. It seems like they are always coming out with a new mousetrap for that one.
I've used the red fiber ones, the blue fiber ones, and the yellow/plastic ones. I tend to like the yellow/plastic ones more than the others. However, the best practice is a new washer everytime you remove the plugs.
Knot 4 Me 12-18-2012 01:34 PM
2 Attachment(s)
Like Brian said, I keep plenty of the blue ones on hand and use a new one every time. I ordered these awhile back from somewhere (can't remember where) that use an allen wrench and have an o-ring. Didn't like how thin they are where the o-ring seats so never used them.
msm 12-18-2012 02:06 PM
Visit an Evinrude Dealer
The white plastic washers that Evinrude uses last forever and are the same size as the crummy fiber washers Merc uses.
seafordguy 12-18-2012 08:20 PM
I'll be the first to admit that part of my problem is that I have never used new ones (so they are at LEAST 6 season's old).
I might try the Evinrude ones.............
Baja226sport 12-18-2012 08:24 PM
I think I have a bag of these in my work shop. Give me an address and as long as they are still there I will put a couple in the mail for you. Merry Xmas!
FIXX 12-18-2012 11:09 PM
Having the correct screwdriver makes a big difference on tightening the screw,i took a black snapon with the black square drive blabe apart and cut 6'' off it and hammered it back in the handle..works like a champ and i onlt use that one out that screw on the outdrives..
