-   -   Polk MM691's VS ? (https://www.offshoreonly.com/forums/general-boating-discussion/289381-polk-mm691s-vs.html)
looseconnection 12-28-2012 03:24 PM
Polk MM691's VS ?
Strongly considering replacing the two 6x9 stock speakers in the cockpit of my formula with Polk MM691's. I plan on leaving the kenwood head unit in place. 50 amps per channel, or am I leaving alot to be desired on the table. Should I amp the new speakers?
Any dealers for the polks on this site, would love to give them $$ instead of MiChongDung on ebay/amazon. No good audio shops in local area.
LC
JRider 12-28-2012 03:39 PM
Polk momos are pretty good bang for buck but unless you plan on adding an amp later you might be overbuying. Regular 691s will sound great powered off the deck. Your deck is more like less than 25watts rms btw.
looseconnection 12-28-2012 03:43 PM
Yes 25rms 50 peak IIRC.
What size amp is needed to fire the MM's to the max capacity?
Nightlife1970 12-28-2012 05:54 PM
No head unit amplifier puts out more than 14 watts RMS. I don't care what they claim for wattage, they all are chip amps and they will not put out more than 14 watts.
With that said I would not run any decent speaker unless I had a real amp to run them. You would be suprised how much of a difference that it will make. Get a 100 watt 2 channel amp, it will be the best money spent.
Cold Sweat 12-29-2012 10:37 AM
Agreed, the db691's will do the job and free up $$$ for a nice amp. I've used Polk speakers in my last 2 boats, never any issues and sound great. I also purchased Polk's 5 channel amp to power everything, which I hear is no longer available.
2-db691's, 4-db651's, 1-MM1240 dvc.
looseconnection 12-29-2012 12:09 PM
Are the db691's rust proof? May do 4 and a 4 channel amp. But how much rms watts per channel is needed. I think they are rated 100rms and 300peak. So will a 4channel amp with 50 watts rms do fine or will it need to be closer to 100 watts rms.
JRider 12-29-2012 12:24 PM
Depends on the amp. If you go with a quality amp, say alpine or JL, the amps will have much better spec sheets/ratings. I would rather have a quality 50w per ch rms than a cheap 75w per ch rms. I know MTX was famous for underrating their amps, they would rate them at 12v supply and the output would be substantially higher at 14.5 volts. I would say you would be good with a quality 50wrms per ch amp with 4 691mms or standards...it should actually bump pretty good.
jwurl 12-29-2012 02:12 PM
I put the 691s in my Fastech. Big improvement but they are still only 6x9s. You can easily get them to distort with just the power of the head unit. No need for an amp. Jeff Wurl
looseconnection 12-29-2012 02:40 PM
Look like I will be doing jbl 6004 amp with 2 or 4 691's. I have a huge list of projects this winter and don't want to rush install of two more 6x9's. May use 6.5's instead of 6x9 under rear bench but am I loosing much doing this?
ondtip 12-29-2012 03:02 PM
Most likely your head unit was maxed out and it was clipping causing the distortion. Any decent aftermarket speaker can handle way more power than the headunit can supply.
Nightlife1970 12-29-2012 04:10 PM
Not the speakers distorting, but the crap amp in the head unit. Get a good amp and really see what those speakers could do.
Nightlife1970 12-29-2012 04:17 PM
I would not put any speakers in the rear bench unless they are subs. Putting 6x9 or 6.5's down there is a waste. Unless you are going to be laying on the floor to listen to them. Put mid/Hi speakers up as high as you can so you can hear them. Put subs close to the floor to get half space gain off the floor.
If you already have 6x9's in the bench, take them out replace them with some 10" subs. Move the 6x9's up higher, and you will make a vast improvement in sound.
Nightlife1970 12-29-2012 04:22 PM
You could run all four 6x9's with two channels of that amp. Then use the other 2 bridged to run a sub.
looseconnection 12-29-2012 06:48 PM
do tell me how.
series or parallel?
I assume parallel.
LubeJobs42 12-29-2012 11:55 PM
I just put 4 sets of MM651's in the MTI i just bought to screw around with. I heard them today for the first time and they really sound great. I think i need to change to larger amps as the cones were bearly moving.
Nightlife1970 12-30-2012 09:23 AM
Originally Posted by looseconnection (Post 3839489)
do tell me how.
series or parallel?
I assume parallel.
Yes you could run one half of the amp in stereo for your 6x9's. Running them in parallel. Then bridge the other two channels to run a sub.
Would not be perfect power for the 6x9's, but still better than the headunit amp.
Would be alot better system than runing four 6x9's off the HU with two of them in the bench. Might as well get you some maximus speakers from the 80's and a Kraco HU for that setup.
Cold Sweat 12-30-2012 12:54 PM
Yes, they are for marine use. Check out Polk's website, or talk to their tech line. I say more power and quality amp=cleaner sound. You'll be amazed how your system will sound with a good amp and speakers. Without an amp, it's going to clip. Picture this, on the water enjoying the day, maybe having a few and you wanta hear your favorite tune. LOUD Not going to happen in an open cockpit boat, all you'll hear is distortion. You can get away without an amp in a car, not in a boat.
Lots of good stuff on the market.Unless you're one of the lucky people from the deep south, you have all winter to shop.
BC
Cold Sweat 12-30-2012 01:10 PM
Just to give you and idea what size amp you can use, the MM,DXi, and db series Polk 6x9 speakers are rated @ 125 watts continuous, 300 watts peak.
looseconnection 12-30-2012 02:40 PM
Thanks guys!
LC
4mulafastech 12-31-2012 11:08 AM
1 Attachment(s)
I'm considering upgrading my stereo this winter as well. Stumbled on these speaker grills that look like will work with the Polk MM691's. A little plain looking, but they offer more protection and will blend better in a mostly white interior.
It is model number DXI69 MG and Best Buy carries them.
looseconnection 12-31-2012 01:42 PM
Cost?
4mulafastech 01-01-2013 10:07 AM
Originally Posted by looseconnection (Post 3840267)
cost?
$30
