-   -   Cmi hp gains (https://www.offshoreonly.com/forums/general-boating-discussion/290007-cmi-hp-gains.html)
DonZ 01-12-2013 04:43 AM
Cmi hp gains
Hi,
i have a 600hp engine and i am currently running GIL exhausts on it with dry tail pipes.....i will be putting a new set of CMI e top headers and would like to know if i will notice any difference when it comes to acceleration, throttle response and so on.....will i gain any hp ?
thanks any info would be greatly appreciated....
FIXX 01-12-2013 03:58 PM
Fixx
Originally Posted by donz (Post 3847117)
hi,
i have a 600hp engine and i am currently running gil exhausts on it with dry tail pipes.....i will be putting a new set of cmi e top headers and would like to know if i will notice any difference when it comes to acceleration, throttle response and so on.....will i gain any hp ?
Thanks any info would be greatly appreciated....
no!...YOU MAY LOOSE TORQUE..
POWERPLAY J 01-12-2013 04:14 PM
Just curious, why?
obnoxus 01-12-2013 04:16 PM
Originally Posted by POWERPLAY J (Post 3847403)
Just curious, why?
Needs a certain amount of backpressure
POWERPLAY J 01-12-2013 04:20 PM
I can understand that. Is it that much of a difference? I am curios cause I am keeping my CMI headers but changing to 5"dry tails.
ita1iansta11ion1 01-13-2013 09:00 AM
i changed from an old set of lightning headers on a 700hp engine to a new set of cmi's. wet vs dry tail pipes. $5000 later i saw no performance improvement.
offshoredrillin 01-13-2013 09:10 AM
Do a little reading on exhaust scavenging and you can learn quite a bit. Sometimes bigger isnt always better. depending on heads cam and such, a little back pressure will help and create more power. if exhaust is too free flowing, that second that both valves are open if the exhaust is flowing too much it can pull unburned charge out of the combustion chamber, therefore nullifying all the effects that you were going for.
Donskihp 01-13-2013 09:12 AM
I have a 496HO and I purchased the CMI sport tubes. Before installation I was running about 4900rpm with a 24" brovo 1 prop an 68mph. With the CMI sport tubes installed I was hitting the revlimiter, I changed to a Brovo 1 26" prop rpms changed to 4800 and I was seeing 69.4 on my GPS
stirling 01-13-2013 11:07 AM
And how is your out of the hole ,and midrange acceleration with the 2 inch bigger prop ?
Unlimited jd 01-13-2013 11:25 AM
Had a customers boat lose 3 mph and 200 rpm going from leaking cmi's to used Gil's..... That come to find out we're leaking at higher pressure also! Doh!
