How to make a 46‘ Cig 12mph faster…
#31
Brad Smith helped design this regulator to protect engines against too much water pressure. It cures the problem of needing to raise the pickup(s) to lower water pressure at high speeds, but in turn do not have enough water pressure at low speeds.
http://www.cpperformance.com/p-16737...ief-valve.aspx
#32
Received 3,020 Likes
From the Powerboat Magazine article:
... The 46 is all epoxy, weighs in at a little over 10,000.
"For hernandez (Neil), it was imoportant that it wasnt a "potato-chip boat" but had a similar weight to the models coming out of the Cigarette factory."
Bud Lorow & crew spent more than four months rigging it.
The power...
570 Cubic Inches
Quad (4) Turbos (hence quadzilla! )
Control System and layout similar to the 1075s
merc. wouldnt say anything else...estimation of 1800 horses
Inline Configuration
Dry-Sump No. 6s spinning Herings
"Tomlinson estimated the V-Bottom would have to run 180 mph exiting the trap to break the record. "Its probably not the thing to do right now," he said.But Tomlinson was confident the boat could run in the 180-mph range provided more work was done to the bottom and setup. "I've never run anything that felt like that kind of power-nothing, ever," Tomlinson said." ...
As a side note, these quad turbo'd "secret" motors were the pre-curser and R&D for the now ever so popular 1350 Turbos. It's like the aero space program. We don't get to know about stuff til yeeeeeeeeeers later.
#33
I believe JT said that driving the boat at speed was like balancing a bowling ball on a razor blade.
#36
It's around. It was the red and white "strength & honor" boat after they cut the top off. Then it was repainted again black and white with new interior and it sold. It runs the FPC poker runs all the time. Sick boat. VERY rare and unique.
#37
[QUOTE=thisistank;3859579]Absolutley correct. The hull was not a Maximus is was a new design that was Epoxy layed up by Skater. It was a true V with no pad because Skip wanted to stay true to the roots of Cig (no pads). It was CRAZY fast! In 2006, Cigarette Racing attempted to beat the Kilo record and recorded a one-way pass of 172 mph, however its average was 163.759 mph.
[I]... The 46 is all epoxy, weighs in at a little over 10,000.
I heard rummours but, Is this the same hull that Skater is offering as the 488V? Does Skater have a pad on theirs? I can't find a pic of the Tainted Lady's bottom anywhere.....
With regards to the Brad Smith regulators - would each motor be fitted with the regulator and do away with the crossover?
#40
How to make ..
Hi,
Depending on what kind of engines you have you should be fine with 15 psi. So you can jack up your engines for sure - and gain speed.
Cheeers, Toffen
Cheeers, Toffen
