-   -   CMI header repair (https://www.offshoreonly.com/forums/general-boating-discussion/291451-cmi-header-repair.html)
Rrice 02-12-2013 09:26 PM
I had a leak in one of my headers and it cost me a motor. I sent them to be repaired to CMI one was fine, one had a leak. They would not repair the leaker or warantee it because it was a header that came on the Merc. 500 hp motor package and they were not of the same standards as the aftermarkets they sold . I tried the best welder I knew and because they are cast stainless, when weld cooled the crack would expand, we made many attempts and it still leaks. I bought a set of KE headers and they work great with a higher power band than the E-Tops. CMI's . I still have one header that was tested by CMI if anyone need to complete a set.
Kat Krazy 02-12-2013 10:03 PM
Yes Rrice I replaced 2 sets of headers on HP 500's with the CMI's after market version of the stock Mercury headers. They weighed also double of the Merc's. I wish my big tubes
were made with the same quality.
the deep 02-12-2013 10:12 PM
I believe if the proper procedures are followed they can be successfully welded . Don't let anybody bullchit ya .
Mbam 02-13-2013 06:53 AM
Yes in most cases they can be welded, the step that most guys miss is "back purging" the area behind the weld with nitrogen or argon. It can be a little tricky to eliminate the hole that wants to form at the end of the weld puddle.
The other problem is once there is too much corrosion there is just nothing left to weld.
