-   -   Mounting brackets for K Planes hydraulic pumps (https://www.offshoreonly.com/forums/general-boating-discussion/291465-mounting-brackets-k-planes-hydraulic-pumps.html)
Smoking Joe 02-12-2013 03:09 PM
Can anyone tell me if the mounting brackets that bolt to the stringers or transom for the Merc Trim pump are the same for merc K Planes hydraulic pumps.
Thanks.
sr73z 02-12-2013 03:27 PM
yes, and those brackets fit the old style tall pumps, and the short pumps with the clear plastic reservoir.
Smoking Joe 02-12-2013 06:44 PM
Thanks mate you are a gent.
O.C.Barry 02-12-2013 07:38 PM
2 types
Thanks.
There are 2 bracket types, the older style has a bolt you can remove to undo the mating brackets and the pump can be lifted upward. The new style is a solid aluinum bracket with a stainless steel retaining bracket. In the newer style you have to unbolt the entire bracket to get the pump off of the stringer.
Smoking Joe 02-13-2013 01:06 AM
Cheers Barry, it looks like the ones I need are the older aluminum ones and hopefully I have a couple sorted.
Many thanks, I appreciate the information.
SJ.
