Adding A/C but dont have shore power...?? >
Old 02-26-2013, 01:27 PM
  #31
Single 30 is MORE then enough power for my 342.
mittens is offline
Old 02-26-2013, 02:37 PM
  #32
CIG3's Avatar
Give me a day or two. I may have about everything you need. Panel, Charger, Shore Power outlet. Won't break the bank either.
CIG3 is offline
Old 02-26-2013, 04:14 PM
  #33
Originally Posted by Full Force
would a panel like this work? I am a budget guy...
http://www.ebay.com/itm/Shore-Power-...8d04be&vxp=mtr
that would work looks like the one in my boat. mine is under the port bolster seat. crap i ment the outher link of the plugin lol
1989mach1 is offline
Old 02-26-2013, 04:57 PM
  #34
Full Force's Avatar
let me know pklease..
Full Force is offline
Old 02-26-2013, 07:59 PM
  #35
Received 4,249 Likes on 1,225 Posts
I had a 6500btu unit in the 33OL and it ran so long it kept freezing up.
http://www.flagshipmarine.com/sizeboat.html
IMOP that units fan was undersized (275 cfm) and improper air flow will freeze up the coil. I added a second supply and it helped a bit.
That unit was on the cheaper side. Having to wake up hot cause it froze up during the night was annoying.
In retrospect the 9,000btu unit has 475cfm and would have been a better choice...
The Unit on the current boat is better quality IMOP
http://www.defender.com/product.jsp?...083&id=1762790
Having a remote control so you do`t have to get up and change the temp is priceless. It`s also much quieter.
Hindsight spending the extra coin on a better unit is very worth it.
I don`t see why you couldnt hook up the ac and just put a plug on the power wires
ICDEDPPL is offline
Old 02-26-2013, 08:05 PM
  #36
Full Force's Avatar
IMOP that units fan was undersized and improper air flow will freeze up the coil. I added a second supply and it helped a bit.
That unit was on the cheaper side. $1200. having to wake up hot cause it froze up during the night was annoying.
The Unit on the current boat is so much better.
Air flow is much twice as good and having a remote control so you do`t have to get up and change the temp is priceless. It`s also much quieter.
my buddy is a marine mecahnic he said the cruisair are very reliable and easy to get parts for, I also have a buddy that has 9000 in his Mistress and its perfect size for it...I am gonna go about that size....
Old 02-26-2013, 08:57 PM
  #37
Full Force's Avatar
hmmmm seems like a good start... and it's new..
http://www.ebay.com/itm/DSR-266-W-A-...e87d43&vxp=mtr
Old 02-27-2013, 06:59 AM
  #38
Mine has frozen up also. What was the "second supply" you added?
firehill19 is offline
Old 02-27-2013, 07:24 AM
  #39
CIG3's Avatar
That really is perfect. Wolf Marine is in Mentor over by Wiseco.
CIG3 is offline
Old 02-27-2013, 08:24 AM
  #40
Firehill; A second air vent, the more air you can flow across the coil the better. Less restriction = more air flow
ICDEDPPL is offline
