-   -   Rocker arms (https://www.offshoreonly.com/forums/general-boating-discussion/293803-rocker-arms.html)
nonstop 03-31-2013 07:48 AM
Rocker arms
Hey Guys, Need some input. Upgrading push rods and rocker arms on my 496 Chevy that is getting a 174 B&M. Came across a Pro Comp rockers full roller (part # PC2305) set for $140.00 new in the box. My came is hyd flat tappet with a max lift @ 571 and wont be going over 5200 rpm. Seems like a good deal but wanted to see if any one has had problems with pro comp.
As soon as I figure out how to load pics I get some of the motor, looking great!
Thanks.
mike tkach 03-31-2013 08:07 AM
pro comp is cheep chinese junk ,when it comes to engine parts,you get what you pay for,spend a little more and buy quality parts,you will be way ahead in the long run.
ROTAX454 03-31-2013 12:07 PM
Mike is correct. Junk. For your push rod needs, go talk to these guys.
http://trendperform.com/
Give Bob Madera a call reference your rocker arm requirements. You will be glad you did.
bad judgment 03-31-2013 01:03 PM
yup yup yup... Spend a little more and get good stuff. Heads and Valve terrain are so important especially in a marine use with long sustained RPM's.
Young Performance 03-31-2013 01:05 PM
In your case, I would use a set of Harland Sharp rockers and Manley 3/8 .080 wall pushrods. Those parts won't break the bank and will outlast the rest of the engine. You will spend in the just under $500 area for both.
Eddie
nonstop 03-31-2013 06:34 PM
Thanks for the help guys! Will make calls tomorrow.
bcfountain 03-31-2013 08:12 PM
If your lookn for a set of sharpes rockers pm me.i think i got a set im not using.
