Common Prop Size for Mercruiser 4.3lx
Hi Everyone, I was wondering what a common prob size is for the 4.3lx (4 barrel carb) mercruiser. Right now I could over rev the engine and go over 5k (I dont know how far over as I didnt want to push it). I know recommended rpm ranges is 4600 to 4800. My prop now is 14 x 23. I was going to go with a slightly steeper pitch but realized thats the biggest pitch for 14in, I would prob have to go to a different diameter. The one blade on th prop is bent slightly but would that really cause it to over rev? I will post a picture of it when i get a chance. I mean I could see if there is a huge chunk of metal off the prop but thats not the case. MY boat is a 19ft renkin bow rider and I believe it is 2500 lbs. Thanks for the help!
Originally Posted by jbizub5192
(Post 3915684)
Check the gearing on your drive . A 4.3 shouldn't be spinning 5k + in a 19' anything with a 23" pitch prop .Something is wrong (slipping) or you have a 4 cylinder geared outdrive.
My first boat was a '93 206 Rinker with a 4.3LX. I ran a 19" Mirage Plus.
Thanks everyone, that's what I kind of thought. Something did not seem right. How can I check the gearing of the drive? Will there be numbers on the drive that identify it if it was a 4 cylinder? I know someone could have just re geared it and if that's the case how would I check for that?
I found a picture of my drive and it says 1.84r. I think that is the correct gear ratio. How can I check the actual ratio? Do I need to remove the drive. My Elevation is at 1128ft if that helps
Something doesn't add up.
Unless it's a very shallow and light boat, that motor in most boats usually only takes a 19 or 21 pitch prop. |
like everybody else is saying thee is a missing piece to this puzzle. i am running a 23p michigan wheel on my 18' baja with a 5.7 and it wont rev into the 5000's
I defiantly agree with all of you. When I was looking around I noticed no one had a 23 pitch prop on a 4.3 thats why I figured I would post the question here because something seemed odd lol. Do I have to take the drive off to check the gearing? If so do i need to open up the drive or can I do it by just counting the turns.
What prop is it? Are you sure it's 23P? Is this an Alpha drive? When I got my 190 it had a 19P on it that was pretty chewed up and it would only spin that up to 5200. When I put the 21 on it, it was over proped and would spin 4400.
Did you check the hub? |
