Adding fuel tanks?????
What is the safest and best way to add additional fuel storage?
I have tanks in the belly now. The boat is a 99 32 active thunder V-bottom I would like to ad about anouther 50-75 gallons of capacity for some extended range cruising. I though a tank on each side in the rear? |
Shane
West marine sells aluminum and plastic tanks in a variety of sizes and shapes, including saddle tanks. If you have room forward of your motors on each side, I'm sure they could be mounted with a little glass work. BTW, forget the electric tank selector valves. I've had a couple different types fail. Use the old fashion mechanical selector valve. Also, I think there's an article on yachtsurvey.com that talks about correct fuel tank mounting. My $0.02 Gary |
I think your first call
should be to IMCO who makes Alum. Tanks... 909-592-6162 ask for fred. second would be Fuel-Safe which is a soft bladder type and they are Bend OR. www.fuelsafe.com. I also have 2 sets of side tanks that were never used send a drawing and I will see if a set will work. Mike J. |
add a fuel blader up front with transfer pumps...the AT is ass heavy as it is right now
well 25 max of it up there any way...your right 50-75...the sides are the only place....:(
where the hell r u going....don't ya have 180 gal to start any way??? |
JOE,Lighten up I might have a buyer for the tanks
here.:D Mike J. |
really it sounds like that is the way he has to go for that kink of fuel requirement....i guess under the engines would work too??? r your fuel safe tanks?...foam or no faom??? what size...
Joe I am nervous about making the bahamas crossing? I have whate ever is standard. I think I have 150 i think.
Gets a little low on the way to KW if I dont stop midway. |
i have 160 total...do u ever get better than 200miles out of that???
I have never actually put it in miles.
| All times are GMT -5. The time now is 02:46 PM. |
