Boat length Pros and Cons
I see advantage of getting a larger boat form the normal 18-20 ft boats, as it rides nicer and can handle bigger waves with ease. Now if I get on longer boat I can run a big block, longer yet twin smalll blocks. If I get to about 30 ft I can run twin big blocks. Now if i run a lakes and such what advantage do I gain by getting a bigger/longer boat at that point? I view ~30 ft boats as the smallest/light boat can handle xxx amount power. It seems like if I get a bigger boat I will just need more power increase just to run what a smaller boat will run with stock engines. What advantage do you get to run a boat longer than ~30 feet? Thanks for the info all. Cyrus |
1 Attachment(s)
Bigger sunpad
Bigger boat = bigger ego. :evilb:
Bigger boats have more room. mine seemed big at first but then i went on a buddies boat that is about 5-6 ft longer. May not seem like a huge difference if you are used to a smaller boat but if you go with a 34.5 baja or something similar(just for example) you can run 60+mph w/496 bigblocks, have a kitchen, shower, a/c, flush out toilet, gernerator, and plenty of room in the cockpit to move around. All stock and nice looking with room for a few extra people to come. You can make runs to marinas and stay on the boat at night instead of paying for dock fees and a hotel. maintenance is usually easier with more room in the engine bays (sometimes). and if you ever do decide to take it to the ocean, the longer the boat the better it handels in the big waves. And definately bigger sunpads!
Originally Posted by POWERPLAY J
(Post 3916845)
and/or smaller man parts (in an effort to keep it somewhat clean)...... :lolhit: |
more room, ususally handle more water, can go faster.
CONS- they are bigger, cant go in shallow water, cost more, cost more to maintain/insure/operate. They weigh more which means you need a truck that can pull it etc. But these are the cons anytime you get something bigger. I think if you start getting larger than 30ft and are looking for speed you start talking big boy money, docking the thing instead of towing etc. |
Bigger Boat= Bigger Repair Bills.....:eekdrop:
where do u boat?
do u overnight on the boat? family? |
Originally Posted by low_psi
(Post 3916876)
Thats the weakest...most immature thought and saying ever...and usually only made by people jealous of others with bigger/better things. Mind you I dont hve a "big" boat....Ive always had BIG trucks...12-20" of lift and I drive them because I LIKE them not cause I have a small penile organ and am compensating. I want a bigger boat cause well....they are cool and bigger sunpads are obviously AWESOME! |
The bigger the boat, the costs go up exponentially. It all depends where you use it, how you use it, then where you can launch it, where you can store it, if you can work on it yourself, etc, etc.
I haven't owned one personally, but been very much involved with a 38. It was not fun, turned into more of a hassle than it was worth. But the circumstances also contributed to that. If I could afford a 38, along with the rack storage to go with it, count me in. For now, my 24 is big enough for Erie, easy to tow/launch solo if need be, storage is easy, so it works for now. I will be looking to move up to something in the 30 foot range in the next two years, and that is as big as I plan to go for the time being. |
| All times are GMT -5. The time now is 04:48 AM. |
