Which Shower Sump Pump?
Need to replace mine, has the original Attwood 750 gph in it.
What should I go with: - attwood - rule - Johnson All are close to one another on the gph and physical size. The only negative I found on the net regarding the Rule is the fittings are fragile and break easily...maybe people tightening too tight though. Suggestions on which one, please. |
No suggestions so I bought the attwood. It is the lowest height of the 3 so it will be easier to install due to the tight space.
| All times are GMT -5. The time now is 07:54 PM. |
