supercharged 540
I'm getting ready to sell a super charged 540 and I'm not sure what to ask so i was hoping someone can put me in the ball park as to what to ask for a quick sale,below is a description of the engine. Engine and trans are very complete including alternator,starter and wiring harness. The engine has very low hours. I was told it was originally built by Troy Dennis and used a few time and put in storage. I did pull the pan and verify what is in it and appears to be fresh. can be started on a custom stand it sits on that goes with it.
- Tall deck bowtie race prep block with splayed billet main caps casting 24502506 - Callies crank/oliver rods/JE piston - Merlin iron heads/severe duty valves/titanium retainers - Crower shaft roller rocker arms - roller cam - polished Moonyham 14-71 blower - polished super chiller - throttle body fuel injection with harness and ECU - Kieth Eckert cast 10qt oil pan with front mount external oil pump - Kieth Eckert sea pump - Older Super cyborg with low hours - dual cooler bell housing - ARE valve covers with oil feeds |
sounds like someone spent 30,000+ thousand BUT used expect 1/3 fwiw if you get 10-12K you will be doing good
Originally Posted by articfriends
(Post 3924068)
Thanks guys
| All times are GMT -5. The time now is 06:49 PM. |
