-   -   Trying to convert Merc Hyd pwr assist steering to full hyd (https://www.offshoreonly.com/forums/general-boating-discussion/296232-trying-convert-merc-hyd-pwr-assist-steering-full-hyd.html)
ROB FREEMAN 05-13-2013 08:19 PM
Originally Posted by MrCIG (Post 3924804)
Was that using the Mercury steering rams?
yes . stuff has gone up . hosing alone is like 4 dollars a foot . I did exactly what youre wanting to do . exactly everything on back of boat stayed . all cable assist inside torn out . full hydrollic to the helm installed with dual powersteering pumps . new canister, lines, filter , bypass valve, fitting ect , helm . it wasn't cheap . but worth it . good luck
MrCIG 05-13-2013 08:53 PM
Do you have the part numbers for the imco stuff.
Mark
pi75 05-13-2013 10:55 PM
Get a hold of these guys,tell them what you need to do. They are full of info and have everything.
http://www.everettperformance.com/
Shalom 05-15-2013 09:00 PM
Yesd... This is the same as I have now....I have hydraulic power assist with two rams mounted between my trs drives and cable from helm to transom. I basically can keep my current rams and tie into inside my engine compartment. But I will need everything forward.....Thanks to all of the responses...Does anyone have any used system available?
Originally Posted by MrCIG (Post 3924589)
No he has the old Mercury external hydraulic steering. With an inside cable helm and wants to convert it to full hydraulic
Looks like the picture. Correct me if I am wrong Shalom
Mark
ROB FREEMAN 05-16-2013 08:50 AM
Mark
go to there site they have the kit listed . only part is the actual length of hydrollic hose , that's really where the money is . I just called them
Shalom 05-16-2013 10:38 PM
Thanks for all the answers...r
Ron Smith 12-27-2013 07:09 PM
How did you make out with your full hydraulic system for your boat and do you have any pictures that you can post for outside and inside your boat?
Ron Smith 01-22-2014 06:24 PM
Hello
I have just purchased a complete external Mercury twin ram hydraulic steering set up to install on my twin TRS Formula.
Would you mind getting me a measurement from the inside of the gimble housing to the inside of the cylinder bracket that bolts thru the transom.
I would appreciate it greatly.
Thanks for now
Ron
