350hp-6.2/bravo and whipple, good combo?
I'm considering a 21 ft Checkmate with a 2006 Merc 350hp/6.2/ Bravo one set up and a whipple on it. This is suppose to result in 450hp and 80+ mph. Boat only has 60 hours total on it.
Bash on Checkmate if you must, I like the brand. But if you could help with info on the power combo please. My intial thought is the Bravo should stand up to this fairly well. How well do those motors like whipple chargers on top of them. I will ask who did the install, as I'm sure that can make all the difference. Can anyone tell me who does this right and what it takes to do it right or if it is just a bad idea? Thanks Rob |
Didnt Uncle Toys have two of them in a 30 Eliminator cat and it didnt go so well...at all
Originally Posted by altamate
(Post 3928232)
Bash on Checkmate if you must, I like the brand. But if you could help with info on the power combo please. My intial thought is the Bravo should stand up to this fairly well. How well do those motors like whipple chargers on top of them. I will ask who did the install, as I'm sure that can make all the difference. Can anyone tell me who does this right and what it takes to do it right or if it is just a bad idea? Thanks Rob Altamate, check out my friend's 28 Checkmate here. He's an engine builder, built the single 400cu smallblock for this build. Bought the boat brand new from Checkmate sans engine and drive. You can pin the throttle at 6000 rpm all day long. http://youtu.be/_aOCPl2VxHM |
I had two 6.2 with whipples and they lasted way longer then they should have. We had another set of motors that were not done in time so I put the 6.2's in as temp motors with the whipples. Then figured in the winter I would swap them out. Well they took a beating and lasted for two whole seasons. I blew one up at desert storm because when I adjusted my rocker arms I forgot to tighten a poly lock. So it kicked the rocker and shut down the cylinder. Then it detonated another cylinder and blew up but I was at wot and 6k when this happened so its expected. Was not the motors fault.
Bottom Line is that it's a great combo if set up right which mine was. They made good power and took a beating. I hear others say they have problems but you only hear about the problems. I would do them again. We did put bigger pan for more oil and put arp studs on the crank caps. But the rods and pistons were stock. Mike |
Cat&Mice, did you have your ECM recalibrated? What was your WOT , drive ratio and prop size?
Originally Posted by spectras only
(Post 3928305)
At that time I had 1:35 gears and 36 bravo. When I blew the motor and put the 407" SBC in I went to 1:24 and had 34 or 35 5 blades ( I can't remember exactly what I had). But let's not get side tracked. LOL MIke |
Thanks. I got the Bravo1X drives with 1.65 ratios and labbed, re-tuned B1 26P. Max rpm is at 5000 ,a few hundred shy of the rev limiter. Turning 36P Bravos with 1:35 ratio is pretty impressive.
To get those numbers with tuning by Dustin is amazing. |
It was a 138 mph twin cat with very high x. With the bigger motors it went 150mph
The pic in my avatar is of the 406" SBC after we took out the 6.2 Mike |
I have a land &sea extion box i bought for my scarab , but i not sure if i going to use it , replaced all bearing bearing , ready to go $ 550.00 shipped all the parts are there , i have read were they work well in checkmate like 6 mph to 10 mph , look it up on the checkmate board and wont need a wipple
IM or cell 716-866-3468 |
what cat do you have C&M?
| All times are GMT -5. The time now is 12:13 AM. |
