Documentation #'s in Bilge???
I was told that I need to some how have my documentation numbers in mounted to the hull in the bilge area. What will the coast guard except and what will I need. I've been planning a lot of trips on the great lakes so I'm sure I'll get stopped since I don't have any OH numbers on the hull.
We used to write it on the Glass of the hull with permanent Marker, Then glass over with one thin layer of Vail cloth. It needs to be seen & be Permanent. They usually don't like anything removable.
Stick-on vinyl registration numbers, and some clear spray paint over the top. Mask off just a small area about 2" around the numbers, and only paint that one spot.
Does the clear spray paint come in a aerosol can or is it clear coat for a gun.
Just clear spray paint from Home Depot or Lowes or the like; Rustoleum. All it needs to do is prevent you from easily getting your fingernails under the edge of the number, and will leave a trace if someone ever peeled the number off.
2 Attachment(s)
Can I put the numbers on the white under the engine hatch or does it need to go on the grey near the battery terminals?
Not on the engine hatch but just above the exhaust.
Just put them on the side of your hull like OH numbers. Look plush
Originally Posted by Sydwayz
(Post 3935554)
I went to Quality Stainless Steel USCG Documentation plaque - DocumentedVessel.com and ordered one of their plates. Looks awesome. Added some 5200 and stuck it to the side.
Originally Posted by TDSTYG
(Post 3935844)
Originally Posted by CrownLPX
(Post 3936045)
Matt you better pack a lunch, eat 10 acres of corn bread and bring some help. And I might just do that one of these days
1 Attachment(s)
Just like Sydwayz said.
Mine is like above but on the side, not the rear.
Wherever you install them, just make sure it can be viewed from the outside of your boat; i.e. standing on a Coast Guard vessel beside your boat. while both of you are floating beside each other. Most of the time, they do not "board" our boats as they know their boots can cause damage.
1 Attachment(s)
Coast Guard information
Oh chit, I went with 2" numbers. I do like where you got yours kjm5125. Back to the store.
Teddy, I got my sack lunch and ill see you this weekend. :angry-smiley-038: |
| All times are GMT -5. The time now is 08:14 AM. |
