-   -   Merc 700sc RPM (https://www.offshoreonly.com/forums/general-boating-discussion/297885-merc-700sc-rpm.html)
ALL_IN! 10-02-2020 09:01 AM
I find it hard to believe that there are presumably several boats with this condition at the same time. Is this a year 2000 clock issue??? lol
I never had this problem on my 700's, sorry can't help - but interested in what you guys found out. I've got a diagnostic manual if you need any screen shots from that.
VoodooRob 10-02-2020 03:06 PM
This is from BUP John Mosetti: The 600 and 700 and so do the OPTIMAX engines suffer failures within the PCM 555 for the coil drivers when a bad ignition coil(s) happens. You can check for faults in with the scan tool to see if any of the coils have failed and or the internal ignition coil drivers in the PCM 555. At times this fault will not show either and or is logged in history
John can test the PCM555 and update the internals. He explained it as we are running very old tech, like an old computer, cell phone, TV, that needs to be current to run efficient, faster and stronger.
Benawe88 10-02-2020 04:16 PM
I would be interested in getting my PCM tested and updated. My Rinda scanner doesn't show a fault. How would I contact John?
zz28zz 10-03-2020 01:09 AM
Originally Posted by bcevans8 (Post 4759698)
Both motors run very smooth and idle at the exact same speed. Both motors will only rev to 4,000. While it is possible that it is a bad coil (coil packs are original), what are the chances that both motors experienced a coil failure at the exact same time?
At 4,000 the motors sound and run great. There is no mis-fire or hesitation.
Thanks.
In the thread you started in the General Q&A section, you mentioned that it ran great before removing the anti-siphon valve, replacing fuel/water separators and replacing all the spark plugs. If you gapped the plugs too wide, the spark will find another place to go when cylinder press reaches a certain level.
bcevans8 06-15-2021 02:02 PM
The issue was the high pressure fuel filters. They were clogged and did not allow sufficient fuel flow at high RPM and full load.
Dean Ferry 06-15-2021 02:09 PM
Yep, the little ones mounted up on the engine...
bcevans8 11-15-2021 07:25 PM
Good evening.
The solution to my RPM issue was the high pressure fuel filters at the back of the engine. They were clogged to the point that they would not flow enough fuel at higher RPM. We replaced them and it runs like a champ.
