-   -   38 cigarette trim (https://www.offshoreonly.com/forums/general-boating-discussion/297946-38-cigarette-trim.html)
David H 06-10-2013 08:33 PM
38 cigarette trim
Hello
Just started getting the 38 Cigarette out on the water. I am having trouble getting it to plane out as fast as my 32 Fountain would. It has 525 motors, 32 pitch boavo one four blade props,approx. 1/2 fuel load,and four average adults. I have to really feather the throttle or the props break loose. What am I doing wrong or does it just take a little longer for it to plane out?? Any advice??
TeamSaris 06-10-2013 08:35 PM
525s and 32s? Seems like a lot of prop for a large boat. What gears? Always tuck it all the way in when getting on plane
J-Bonz 06-10-2013 09:22 PM
Don't forget throwing the tabs down to. 38 top gun, I will guess you have either bravos or TRS's. it's a heavy boat. Best to take it easy getting on plane. As for props, I am not sure
johnnyboatman 06-10-2013 09:43 PM
2 totally diff boats, the fountain is smaller and lighter, the cig is heavier, give it a few outings and you will get the hang of it.
Joetool 06-10-2013 09:43 PM
What type of drives Sportmasters? I had the same boat for three years same power and Sportmaster drives the boat hates getting on plane but this is what I did. First tuck the drives all the way in and set tabs a little lower than neutral setting the tabs down too far lifts the stern up which then breaks the props free. I always made sure I had a clear path in front of me. Keep trying different tab settings it will get up on plane. Good luck Joe
TxHawk 06-10-2013 10:30 PM
I always found that with these high X sportmaster boats that slightly turning while planning helped out quite a bit. Try a big diameter prop 35 Fountain with -2's. That will embarrass you at the bouys!
Sydwayz 06-10-2013 10:55 PM
What year is this 38TG in question?
Twin step or straight bottom?
525SCs or 525EFIs?
4195 06-11-2013 09:36 AM
Originally Posted by TxHawk (Post 3940625)
I Try a big diameter prop 35 Fountain with -2's. That will embarrass you at the bouys!
What does this mean?
Mastercraft240 06-11-2013 09:44 AM
I think he means in the turns.
Unlimited jd 06-11-2013 09:57 AM
I'm guessing t/s 525 efi's my buddy has an 03 and 32 bravo 1's is what he runs. Its and -2 lowers. Sucks getting on plane. Drop the tabs, tuck the drives and feed it throttle seems to work best for him. Right wrong or indifferent it works
