What caused fuel to get in my oil? Could this have caused the engine to blow up?
I assume you are running the stock EFI. What did you do to get the extra fuel to run the super charger? Is the pressure boosted? Is it high enough to leak past the injectors? It takes a LOT of gas in the oil to blow an engine. The chances of a bad injector or a fuel leak happening to both engines is slim. Look to the mods to your fuel system and you will find the culprit. Good luck, sorry to hear of the repeated problems.
[img][/img]
[img][/img]
Uncle Toys,
I'm sure you may have seen me mention this guy's name a few times in the past----Bruce Wolff (S.W. Michigan) has solved SEVERAL problems with the Whipple charger set-ups. Bruce is an excellent trouble shooter when it comes to jetting/tuning, timing, EFI, etc. He just fixed a dude's boat with a pair of big block whipples in it----it was WAY too rich! The guy had apparently taken it to 2 other shops with no positive results before he took it to Wolff. Bruce fixed the problem and the guy is very happy from what I understand. I don't know who the guy is who took his boat to Bruce, but apparently he got Wolff's number from this forum when I posted it in a thread for someone else who was having problems. Wolff used to work for John Lingenfelter years ago and did a lot of trouble shooting/track tuning for John's cars at the strip. He's very knowledgable and perhaps he might be able to tweek you in over the phone without looking at it being that you live in CA. Anyway, might be worth giving him a call. Wolff's shop # is: 616-422-1090 8-5 Eastern time
Hope everything works out for the best with you and your boat
Official OSO boat whore
I'm not real familiar with this small block installation...most carburated small blocks have a block mounted fuel pump. Do yours have a mechanical pump? Often what happens is that the diaphram ruptures causing fuel to leak into the crankcase. On marine engines there is (supposed) to be a hose leading from the pump up to the carb to prevent this from happening.
If you have a electric pump (which I assume you do) what was the pressure set to? If the pressure was set really high, I suppose it could overwhelm the injector and cause the motor to run really fat. But for that to happen you'd know it because the motor would run like chit.
If I remember Cat & Mice blew the bottom out of a small block alos. Does he have the same engine.
Cig1 – I’m starting to think you are on the right track. Talked to a guy today who thought the 6.2 Merc engine is not suitable for blowers. Something about the rings not holding up to the pressure. I need to track down someone at Merc to talk to about this.
Audiofn – Your right, the blocks couldn’t be more stock.
Turbojack – Yes, your right, we smelled the gas on the dip stick. I never would have thought about trying that, but the mechanic that was on board is a very senior moter & blower guy and he picked up on it immediately. When Semper pulled the plugs they didn’t look bad, but then, at that time we were still looking for evidence of top-end damage. We were no where near starting to think about fuel in the oil. As far as the rings, isnt it beyond probability that two new Merc engines came out with bad rings? I have a bunch of pictures from Fresno I will dig out. “Do you ever check the oil.” Yes, I am fairly anal-retentive. With total time of 71 hours, I have had the oil changed three times. The good thing for my case was that when I filled up the gas four days before the blow-up, I had a member of this board on the boat with his wife and kids. While I was filling the tanks, he did the oil check. Cat & Mice started with the same 6.2’s, but they were modified a lot, plus he was running a lot more boast.
BruceK & Cord – They are EFI.
GO4BROKE – Your way past my technical ability. Maybe Dustin can address your questions.
KAAMA – Great idea, I’ll give him a call. Thanks!
What do you guys think (in general) the chances are of a stock small-block Merc, with low hours, blowing up because of fuel in the oil?
Uncle Toys: If the rings went out on you I would guess VERY GOOD!!!! The good news is that if you do a rebuild and use better pistons and rings (maybe sevear duty valves) You should be good to go. There are plenty of reliable blower motors running out there. You just have to find the right combination.
UT- Heading out to lake tommorrow to meet up with a guy that one of the trouble shooters for wakasha (spelling) engines. They build industrial big motors. I will ask his take on this. He is the one that taught me about detonation. Mater of fact the company he works for is the one that make the motor to test octane of gas. While I am on the subject of detonation it can make a motor's bottom let loose. I never had that problem. I just was (hopefully) hell on pistons, cyld. walls, heads & valves
Can it happen? Yes. I am curious if the pistons show any signs of detonation at all. Between the two (detonation & gas in the oil) then maybe.
