-   -   Need help asap (https://www.offshoreonly.com/forums/general-boating-discussion/298196-need-help-asap.html)
32 Active Thunder 06-14-2013 08:45 PM
Need help asap
1 Attachment(s)
Where is the drain plug on this drive not behind prop don't see it on back
32 Active Thunder 06-14-2013 08:46 PM
Call me 6084494992
tomtbone1993 06-14-2013 09:24 PM
Check in the front of nose cone
32 Active Thunder 06-14-2013 11:11 PM
It's not in front of cone il
trc2 06-15-2013 05:51 AM
look on the sides on the bottom side of the bullet
Patience...myass 06-15-2013 06:35 AM
From the pic it looks like its broken off
32 Active Thunder 06-15-2013 07:39 AM
It's not on the bullet!! Would it be behind that first retaining ring??
the mayor 06-15-2013 08:08 AM
No
If it's a bravo that should be it right there. Looks like you have scratched around on it. When was the last time it was used?
Formula311-SR1 06-15-2013 09:41 AM
I agree
boatnt 06-15-2013 09:46 AM
Not sure that it looks broken I would think you would be loosing gear lube if it was broke,,sealing washer would be missing,,,from your avatar looks like you have twins,,remove the prop on the other drive and see whats there
low_psi 06-15-2013 10:16 AM
Yup, that site has the look of having the head snapped off......
FIXX 06-15-2013 12:24 PM
like mentioned looks like it sheered off,try taking a center punch with a needle sharp point and put a punch mark on it,,noe hold the punch to the right and try tapping the end of the punch counter clockwise to unscrew the plug..
32 Active Thunder 06-16-2013 01:31 AM
Update here's what happen last owner put set of nose cones on and 5200 hundred them went as far as taking the 5200 over the drain plugs. I have never seen anything so crazy needless to say I spent all sat taking of 2 nose cones grinding down taking the bravo 1 s back to original.
32 Active Thunder 06-16-2013 01:32 AM
Thanks for the ideas!! I thought I was going f ing nuts
cp5899 06-16-2013 07:23 AM
Nose cones are only glued on? I didn't think 5200 was that strong. Wow!!
boatnt 06-16-2013 09:55 AM
Yep,,did not think they were broken off because it would be leaking oil,,besides the bolt would have worked its way off been NOT a pipe thread,,
are you putting the nose cones back on?
32 Active Thunder 06-17-2013 11:12 AM
No I'm not putting them back on they are in great shape just need to be cleaned up!! If anybody wants them make me an offer or I need a bravo 1 tie bar with saddles would do some trading.
FANTAZ28 06-19-2013 05:04 PM
Your Pachanga have AL numbers on it? I was the one yelling at you on sunday in the 353 fastech! I thought I recognized the boat. haha
