-   -   removing painted on registration numbers. (https://www.offshoreonly.com/forums/general-boating-discussion/298559-removing-painted-registration-numbers.html)
shekmark 06-21-2013 01:46 PM
I have to remove the previous owners registration letters and numbers.from my Imron painted hull . Oven cleaner and magic erase or eraser wheel have been suggested. Don't want to f up my paint. Are these the right way? Thanks.
low_psi 06-21-2013 02:15 PM
Was going to suggest Oven Cleaner. Could also Wet Sand with a block. Just have to be careful not to sand too far into the Imron......
redsled33 06-21-2013 02:49 PM
Oven Cleaner should not mess up the paint. We use it in our shop to remove hand painted pinstripe
fastdonzi 06-21-2013 02:51 PM
What kind of paint are they painted on with? If it's just lettering enamel then Oven cleaner will work, just leave it on 2-3 minutes at a time, if it's on too long it can soften Imron and Gelcoat.
shekmark 06-21-2013 03:03 PM
Thanks to all! I will try the oven cleaner later .
grads2112 06-21-2013 03:33 PM
FYI--- If the numbers are close to the rub rail try not to get the oven cleaner on the plastic part of the rub rail, it can discolor it.
runninragged 06-21-2013 04:01 PM
I would try a small spot first just to make sure it does not soften paint graffetti remover works too
Fischan 06-21-2013 04:20 PM
Mine was painted with purple paint. Nothing, i mean nothing worked well enough for me. It took the registration number off but i could still see the old with the right angle. We ended up finding white rectangle with black number/letters inside at Meijers. It covered the old and only cost around $6 total for letters and numbers. Good luck!
beaver 3 06-21-2013 11:58 PM
Yea I'm sure it did but mailbox letters are ugly. I suggest sanding by hand until they are gone. Working up in grit as they disappear. That way you don have to worry about messing up the base with a chemical. Then finish with a high speed buffer with rubbing compound. That should get you down to the gel/Imron without messing it up any and the ability to paint or sticker over top just fine. It's the most labor I tensive but you get what you pay for.
FIXX 06-22-2013 12:11 AM
fixx
GRINDER:eekdrop::party-smiley-004:
